My Philips 46PP9302 46 in is making a chirping sound
  • leapinglily Jul 29, 2008
    My Philips 46PP9302 46 in is making a chirping noise I have had this tv for 5 years and have had it fixed twice in this time now they want me to pay 500 dollars to fix it again. Is there a cheaper way?
  • 3,459 Answers
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Posted on Mar 22, 2009
  • 2,326 Answers
A cheaper way is a DIY but it seems like this failure is not a DIY.
I would say that for a 5 years old TV that has been fixed twice and requires a repair again, I would save the $500.00 to buy a new TV instead of fixing this one.
Good luck.
Posted on Jul 29, 2008
Phillips television making a chirping noise
Replace the flyback transformer anmd HOT transistor, Thats usually whats wrong when the set makes the chirping sound.
Oct 10, 2011 | Philips 60PP9202 60" Rear Projection...
Will not turn on anymore.
A chirping sound can indicate a significant problem with your Philips television. Chris Stein/Digital Vision/Getty images jQuery(document).ready(function(){ jQuery('.intro .thumbnail a:first').attr('href','http://i.ehow.com/images/a07/1e/dm/philips-turn-making-chirping-noise-800X800.jpg'); });
So your Philips television won't turn on and is making an annoying chirping noise in place of showing a picture. Televisions have become more and more complicated over the years, and harder to repair by non-experts. As with most electronics, there are a few simple fixes that might help. However, a chirping noise generally indicates a serious problem that might require a trained expert to repair your Philips television.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Compressed air
  1. Spray a few shots of compressed air into the vents of your television. Over the years, dust can build up and cause signal blockages or small surges within your system. Removing the dust can help clear out these problems.
  2. Completely disconnect your television from all power sources as well as any components, and leave it this way for up to four hours. This will perform a "hard reset" on your television and, combined with the dust removal, might clear out any blockages that exist.
  3. Call a trained technician to repair your television. The chirping sound indicates a problem with your power transformer and adapter. This will likely necessitate a new part for your television.
Jan 09, 2011 | Philips 42PF7220A 42 in. Plasma Television
No picture No sound, chirping from a board
Is the FBT,the high voltage transformer.The big black block of plastic with a red wire solder to a board.MIght even have to change transistors deflection board also.
Nov 21, 2009 | Philips 60PP9352 60" Rear Projection...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
On off button blinking.
If your set is making a high pitch sound or chirping sound you can get a repair kit from www.TvRepairKits.com.
It will fix the no audio + no video + set makes chirping or high pitch sound.
Dec 27, 2008 | Philips 43PP9202 43" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
