Question about Sony Cyber-Shot DSC-S40 Digital Camera
White screen My screen is white and I'm not even able to take a photograph. It's just white. Any suggestions?
  • Tisa1 Jan 17, 2009
    When I turn on our Sony Cyber-shot S40 the screen is white and I cannot take pictures. Anyone know a solution?
    Tisa Stripling
    Technology Specialist
    Glanville Elementary School
    tisa.stripling@cowetaschools.net
  • TIMSK Mar 02, 2009
    I have the same problem I deleted some pics , put in batterys turn the camara off and about 10 min later there was a white screen could not take pics and any other mode would not show... Can you help .. Do you know to fix this
    Thank you
    Kaye Gillman
Turn the camera off, then holding all the buttons in the circle on the back of the camera (up, down, left right and select buttons) with your thumb, turn the camera on. This may take a couple of tries, but it does work as I have the same problem on my camera.
Posted on Feb 24, 2009
Try sqeezing the camera where the sony logo is under the lcd be firm but dont overdo it it should work hope it helps.john
Posted on Mar 26, 2009
The above solution is correct. thank you ccrazed.
Posted on Mar 25, 2009
Replacing 3 pin plug on block heater cable 2003 impala ls. what wires go clor wise into plug
i think you are they should be color coded and match up directly .....however if you changed the wires completely they i would suggest find another 2003 Impala and either photograph it or write the sequence down a dealership will allow you to look at the motor even if you have to pretend you want to test drive it or just look it over
Sep 20, 2009 | 2003 Chevrolet Impala
In camera mode the display turns black and white, and so are the pictures taken. No setup changes seem to work. ???
You mean to say whatever photographs you click comes in black and white photograph or nothing at all comes. Go to camera select options select effects and then select normal. If still the photographs are black and white kindly comment back.
Sep 16, 2009 | Sony Ericsson W380i Cellular Phone
My Sony Camera screen when i turn it on is white & has a pink line going diagonally through the screen
A multicolor vertical line may display on the camera LCD screen if there is glare on the subject being photographed. Avoid photographing very shiny surfaces that reflect excessive amount of light into the camera lens. Follow the procedure below to resolve this issue:
  1. Record the video or click the still pictures in a different lighting environment.
  2. On the camera, move the FOCUS AUTO/MANUAL switch to AUTO .
  3. Set the PLAY/STILL/MOVIE selector to MOVIE or STILL .
  4. Press the WHITE BALANCE button until the white balance is set to AUTO (no indicator).
  5. Record the video to new media.
  6. NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required.
Aug 13, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Camera Screen does not show any picture
Are you sure that you have the EVF/LCD button is on LCD?
Jan 02, 2009 | Kodak EasyShare CX7300 Digital Camera
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
Whitewashed screen
bring it to the service center for a check up
Aug 05, 2008 | Samsung Syncmaster 940BW LCD Monitor
Sony Cyber-Shot DSC-T2
Hey marafioti14,
What you need to do is select shooting mode and then under that you need to select program mode, and under program menu you need to select the color mode which should allow you to set the camera to take black and white photographs. This being said I would suggest instead of shooting the images in black and white it would be better to convert them to black and white using computer software. It is likely that the software that came with the camera allows you to convert any image to black and white. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 13, 2008 | Cameras
XT problem with white balance/aperture
You should be able to set your white balance by taking a photograph of something white filling the screen with the correct exposure. If it is underexposed, you will not get white, it will look yellowish. Make sure while you are photographing the object, you switch your lens focus mode to manual.
Go the second setup (tools) tab and select custom wb. The custom white balance screen will appear and you will choose the image that you want to base the white balance off of by pressing the set button.
This will take you back to the menu. Go back to white balance and choose custom wb down in the bottom right corner of the screen.
Hope this helps!
Jun 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Screen is white and doesn't display area being photographed. Can take pictures.
From camerahacker.com:
1. Hold camera firmly in left hand.
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
Worked for me :)
// Maxim
May 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Losing green / torquoise tones
I'm betting you just have to adjust the white balance properly.  The D80 allows you to set the white balance against a grey target.  There are two ways of doing this.  First, you can put a reference grey target right on the painting, set it, and then remove the target while using the white balance you just set.  Alternatively, you can cover the lens with a diffuser of some sort, like a piece of white paper and hold the camera right where the painting will be, but pointed back towards where the light is coming from so that the diffuser is being bathed in that same light.
In case you don't know how to set the preset white balance, I suggest checking the manual.  I use a D70s, so the procedure may be very slightly different on the two cameras, but the idea is the same.  The key is that if you do this, you are pretty much guaranteed to get proper colors every time - not just now, but anywhere.  I do this often.  All that is required is a perfectly neutral patch (white to black, but with no color at all) that is being lit with the same light as you are trying to photograph in.  It takes about 5 seconds and presto - perfect white balance.  Note that this is for making pictures that look EXACTLY LIKE THEY WOULD IN PURE WHITE LIGHT.  So, it isn't for capturing proper sunsets, etc.
Good luck.
Jan 17, 2008 | Nikon D80 Digital Camera with 18-135mm...
Sony Cyber-Shot DSC-S40 Digital Camera Logo
181 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
