I have three Alba CTV840/A 14" colour television sets purchased in 1996. These TV's each have a single 75 Ohm Antenna input socket. Please advise me, is there an adapter/modem available which will enable these TVs to receive the digital signal when the terrestial signal ceases next year. Many thanks
    Genius:
  • 2,035 Answers
There wide range of adapters which convert digital signal to RF signal which can used on your tv which is available in local tv stores or on ebay...
Good luck..
Posted on Jul 29, 2008
    Master:
  • 726 Answers
Yes there will be im in australia and we have them allready
  • chris07551 Jul 29, 2008
    but there $40 dollars here hahaha
  • 10,594 Answers
I hope, when terrestial signal will cease, there would be solution in market to watch digital signal on analog tv sets.
After scanning channels tv still does not have picture or sound
What type of input and what type of cable have you set to ?
(a) Antenna - Coax cable (75 ohm)
(b) STB - HDMI
(c) DVD - HDMI or
(d) DVD - Red+White+Yellow
(e) DVD - Red+White+Optical (if your TV and DVD support it)
Most TV cannot find any channel when scanned without a proper external /internal antenna
Aug 11, 2016 | Element Electronics FLX-3211B 32 in. LCD...
Fm aerial connection ?
Both of my Marantz receivers use a 75 ohm coax input. The receivers included a single wire antenna that simply plugs in. The plug is suitable for coax cable going to an external antenna. You can also get a small 75 to 300 ohm transformer that will allow you to use a dipole or other common indoor FM antenna.
Feb 11, 2015 | Marantz Audio Players & Recorders
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Antenna cable missing for Panasonic sa-pm42 stereo
782d9ae8-52f7-4cc4-a661-56731bddb11f.pnge94ad7da-0a4e-4d24-aacd-af1ae2881119.png980b7cad-16b3-4152-9d9b-f008ef27d842.pngThere are two types 300 ohm and 75 ohm. Some amps have both types of connection.
The 75 ohm type use plugs and cables commonly used for TV aerials and Satellite dishes.
The 300 ohm type uses screw clip terminals where you attach a coloured cable.
All shown here: The FM socket with the thread on, uses a Satellite connector plug.
May 28, 2013 | Audio Players & Recorders
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
HAVE A MEGALOOP+ hearing aid SYSTEM. THE SOUND FROM A NEW DIGITAL TV IS DISTORTED CAN I ALSO PLUG IN A MICROPHONE TO USE WITH THE NORMAL SCART ATTATCHMENT IF SO WIRING INSTRUCTION PLEASE
I would imagine the level is too high. Does your loop amplifier not have a sensitivity control?
You could come out of the scart socket but check for a headphone volume control first!
The connection standard requires that the pins are utilised in the following manner:
Hope this is useful.
scart.gif PIN USE LEVEL / IMPEDANCE 1 Audio Output (R) 0.5V / 1K-ohm 2 Audio Input (R) 0.5V / 10K-ohm 3 Audio Output (L) 0.5V / 1K-ohm 4 Audio Ground -------------------- 5 Blue Ground -------------------- 6 Audio Input (L) 0.5V / 10K-ohm 7 Blue 0.7Vp-p / 75ohm 8 Status (CVBS) L:0-2V H:10 - 12V / 10K-ohm 9 Green Ground -------------------- 10 Data D2B (Inverted) -------------------- 11 Green 0.7Vp-p / 75 ohm 12 Data D2B -------------------- 13 Red Ground -------------------- 14 D2B Ground -------------------- 15 Red 0.7Vp-p / 75 ohm 16 RGB Status/Fast Blanking L:0-0.4V H:1-3V / 75 ohm 17 CVBS Video Ground -------------------- 18 RGB Status Ground -------------------- 19 Composite Video Output 1V / 75 ohm 20 Composite Video Input 1V / 75 ohm 21 Case Shield ---------------------
A 21 pin SCART cable with all pins connected is wired as per the following diagram:
Jan 23, 2011 | Televison & Video
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Aug 21, 2010 | Televison & Video
300 OHM Feeder connection
A Portable TV uasually has a 3.5mm phone jack as the antenna input, if you can't find the proper matching adaptor, try to construct one using a 3.5mm plug & an antenna maching transformer solder each side with short lenght of 75 ohn coaxial cable
Jun 22, 2009 | Televison & Video
Do I have Progressive Scan on my TV?
component video is HD of sorts lower end of the scale. Your set has progressive scan..
Mar 26, 2009 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
