Question about Compaq MV 540 15" CRT Monitor
Monitor out of range when a game is booted up
HI all im new here so here it is... I have this compaq mv540 monitor and a new compaq computer. i have win.vista home basic. my system model is SR511ONX. AMD athalon 64 processor 3800+ 2.40ghz. i have 2046 in ram. my system type is a 32 bit operating system. MY video card is an nvidia fx 8600 or 8800 i forget.
I play Warcraft III the frozen throne and it starts up fine but when it goes to the main menu of the game my monitor goes black and an error message appears on my monitor says "out of range set resolution lower or use monitor guide". I have no idea why this happens as i tried another monitor and i didnt get an error message but the screen went black none the less and i could not see anything. I have tried to run the game in 640X480 screen reso but same msg applies also i tried setting reso from video card from 1024X768 to 800X600 ( these are the only two resos i can choose)
my other computer i have has xp and the game runs fine and i have read mix reviews before that some ppl have problems with this game and vista but so far from what i have read i have not read anything about a monitor problem for this game.
ANy help wil be much appreciated ty.
  • 1 more comment
  • Anonymous Nov 30, 2008
    i have this problem
  • Anonymous Dec 03, 2008
    hey i hav same prob but it happens when i turn on the computer not even a game in it!
  • Ildamos Jan 07, 2009
    Yep we have the same problem with my AOC 771S. I recently bought this monitor and
    everytime I play a game at 640resolution, it can't display the game
    right. Only at 800X600 resolution or higher can it display video games
    correctly. This is a huge problem with games that my PC can't run at
    higher resolutions. Total letdown. Now I have to save for a new gaming
    rig. Tut.
    President:
  • 2,992 Answers
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Posted on Dec 01, 2008
In same games as Jewel Quest 3 the monitor give this message the single over rang
Signal OVER RANGE?
Monitor unable to cope with the frequency the computer is sending (for want of a better explaination.
Boot the computer to VGA mode and adjust the display settings, or boot to safe mode
Jan 04, 2011 | GNR 19M1 19" LCD Monitor
Tip
I have found that this tip worked for my Compaq MV540 - press the diamind button...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Jun 09, 2008 | Sony SDM-HS73P 17" LCD Monitor
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
Jan 22, 2010 | Compaq MV 540 15" CRT Monitor
CRT Monitor Stuck In Stand-By
So the monitor is not bad try to disable the video card from bios if possible and firstly remove all external devices (USB's) and gets the safemode meny and select vga mode and disablem the video drivers and uninstall and reinstall the drivers
Jul 01, 2009 | Compaq MV 540 15" CRT Monitor
Compaq mv540 monitor does not come on when i turn the computer on. the green on line turns orange
in a technical language you can say its a display problem. the monitor is fine.its actually the problem inside the pc.either some connections are loose or the ram memory needs to be cleaned or some part is gone faulty which needs to be checked.if any of this happens the display wont come.check all the above possibilities to reach the cause and solve the problem. please do rate the solution,thanks.
Jun 12, 2009 | Compaq MV 520 Monitor
Microphone does not seem to be working
The microphone connector is on the rear of the monitor, and you need to connect it to your computer's microphone input jack. The cable is the same kind you would use to connect the audio output jack to the input on a set of computer speakers. Once the microphone is plugged in it works just like any standard microphone. No special drivers are needed for the monitor, but you do need to be sure that the proper drivers for your computer's sound devices have been installed.
If this solution has been what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | Compaq Computers & Internet
Brightness control+blurrness of images+
no can do. you monitor is dead in the water.
lost of focus, and intensty. all point to one thing.
by the way, do you have the correct video driver installed???
Jul 01, 2008 | Compaq MV 540 15" CRT Monitor
Getting my speakers to work
with PC it's in the back with the "Sound" or ear phone icon sticker.
May 13, 2008 | Audio Players & Recorders
Monitor problem
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. May need to check the caps in the G-2 supply circuit. Also you may have a CRT going flakey. Just a slight G2 level adjustment may suffice also. Good luck
May 19, 2006 | Compaq MV 540 15" CRT Monitor
Compaq MV 540 15" CRT Monitor Logo
715 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
