Question about JVC AV-48WP30 48" Rear Projection Television
Red and Green vertical lines (pinstripes) on video source only!
I have red and green vertical lines across the entire screen top to bottom when viewing any video source but NONE inside of the video MENU when I select that... I suppose it's something related to the convergence board but want anyones experience/knowledge on this...
Thanks,
  • 1 more comment
  • Maximum13 Aug 03, 2008
    My JVC I'art Pro 48 inch is starting to do the same thing... I am getting streaks(sometimes flickers) of red and green across the screen periodically, and it seems the longer the TV is on the worse they get... I have already had the board repalced for the convergence once before, about a year or so ago, and the repair man said it hafdto do with heat problems... Has this happened to anyone else, or have they figured out what it is...
    Dan
  • Tony S Aug 17, 2008
    It's a projection TV not a CRT TV so I guess some of what you are saying may still apply? When I test convergence it is perfect and the only time the pinstripes appear is when an external signal is present (that is to say the MENU and convergence screens have NO pinstripes in/thru them). Even when the picture is up with pinstripes I can bring up the MENU and inside the menu will have NO pinstripes... Don't know for sure what board/circuit is between the signal input and the actual screen output but it seems to be there...??
  • keith777 Mar 05, 2009
    i have the same problem. i tried checking the crt boards and they appear ok. i unplugged 1 at a time also. i noticed that the convergence ics are different. one is 110 the other one is 120.
    the are interchangeable. any ohter ideas?
I had this problem, I just fixed it myself. I'm am not a tech or a pro by any means, but I am short on funds and repairs were not in the budget. I figured I had nothing to lose so I wanted to share what I did and maybe help someone out. This is to be done at your own risk, you could shock yourself or break something else.
First off, I had the conversion circuit changed a few years back. These TVs are famous for them going out, so I knew it wasn't that.
I removed the back of the TV and the plastic part that houses' the connections (RCA jacks, S-video,etc) Behind that there is a circuit board standing vertitcally incased in a metal case. I simply wiggled it back and forth and the lines went away. That told me that something was going on there.
I removed the circuit board that had the RCA jacks to make some room( I would'nt force anything in there, take your time and be sure to unclip the circuit board) I then unscrewed the "metal case" and took it apart. I dusted everything and put it back together exactlly how I took it apart. I then cleaned the lenes.
It works great now and it only cost me a hour of my time. The picture is as good as new. I hope this helps somebody.
Posted on Jun 14, 2010
    Novelist:
  • 132 Answers
I have fixed many of these TVs and don't reccomend that inexperienced or untrained consumers attempt any repairs. You may hurt yourself, others or the TV.
It sounds like it may still be convergence. Look in Convergence Gallery.
If not convergence, tap the crt boards gently from different directions. (through the front inspection panel) Tap the crt necks gently as well. Tap with the plastic handle of a long screw driver, don't use the metal end to tap or probe with. Watch the picture for microphonic effect, pic "jumps or changes" when you mechanically tap.
The TV is on and operating so the possibility of lighting yourself up exists. Tapping or probing is done with the plastic end of the screwdriver, one handed. You can't be holding the frame of the tv with your other hand, or sitting on a tangle of cables that connect the 3 vcrs, 2 games, laptop and FTA sat receivers.
Do not ever touch any innards with your bare hand when the TV is plugged in, unless you know specifically that the item/control or whatever is safe to touch. Turned off is not good enough as all modern TVs are still partially operating in the "off" mode.
Do not play with the other items on the CRT neck as many hours of time may be wasted re-aligning.
If the picture jumps or reacts to the tapping turn the power off. Unplug the TV.
There are a number of conditions that may exist.
1. CRT is defective with internal Heater cathode leakage or other fault. Typical shop estimate CRT +$300, Labor $2-400 Handling extra. JVC CRTs are rarely defective.1time/100 complaints
2. Circuit on CRT board is defective. Usually the only defect is poor solder connections. Bad solder connections 1 time/10 complaints
Typical shop estimate CRT Board +$150, Labor $2-400 Handling extra
3. Pins on CRT are dirty, corroded or loose in the CRT board socket. A poor electrical connection occurs between one or more crt pins and the socket on the CRT board. Tapping and moving the board makes and breaks the electrical contact and the pix jumps (for that color)
This is the most likely problem if it is not convergence. 9/10
The fix is simple.
Use a very small jewellers screwdriver with a flat blade. Scratch the corrosive coating off the crt pins one at a time. Start at one pin and work your way around the base of the crt. Just a minor, gentle scratching that does not bend the pins. The corrosion may coat the pins and appears as black or grey varnish instead of metallic.
After scratching the pins, each pin is bent the smallest noticeable amount outwards. Then the crt board and socket is re-installed. It will now fit tight and require some wobbling back and forth to re-install. If any serious resistance is encountered stop immediately and examine the bent pins, one or more is bent too far.
Forcing the socket on the crt when a pin is mis-aligned can break the pin or crush it against the centre. If you damage a pin, crt is junk.
Only attempt repair on the the crt socket giving problems. Preventative maintenance is not a good idea in this situation.
If cleaning and bending the pins doesn't fix, then check CRT PC board for bad solder connections on the crt socket/board connections. (circular pattern)
If you live around Calgary, call me , if not, find someone competent.
easyab
Posted on Aug 15, 2008
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
Green vertical lines across screen
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Nov 30, 2013 | Samsung LN-S4695D 46 in. LCD HDTV
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
My screen has a vertical line red-yellow-green from (top to bottom) that stays there. How to fix it?
I do not know any setting that makes a vertical line red-yellow-green from (top to bottom)
If you can find a monitor to connect to and know how to tell the PC to send a signal to it (ie, on a Dell it is Function F8) you can determine if it is your Video card or your screen that has failed. The Video card is part of the Motherboard and very challenging to replace. The LCD screen however is not as expensive and relitively easy to replace. You can watch YouTube videos on how to. A screen can be found at sites like Amazon and EBay.
http://www.amazon.com/Compaq-Presario-CQ70-120US-SUBSTITUTE-REPLACEMENT/dp/B005788D22
http://www.ebay.com/itm/NEW-COMPAQ-PRESARIO-CQ70-120US-LAPTOP-LCD-SCREEN-17-/200514204266
Aug 20, 2011 | HP Compaq Presario CQ70-120US Laptop
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
971 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
