Question about Canon DR-9080C Path-Through Scanner
Undefined String I let someone use my computer-they tried to help clean things up; but deleted out all Canon & capture perfect files. I did a restart from an earlier date that I thought should reinstall them. When I get into capture perfect it opens but says "undefined string" everywhere and wont work. Is there an easy fix for this?
Reinstalloing
Posted on Aug 11, 2008
    Novelist:
  • 104 Answers
Reinstalling the driver and the application from the CD supplied with the scanner will resolve your issue.
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
Log in error
additional info needed :
logging in from a computer (specify type and OS) ?
browser of choice ? tried clearing browser history? have you tried another browser?
Oct 10, 2008 | Yahoo Mail
I'm trying to load my photos from my camera to my computer and I'm getting a message that says "Save Folder Not Found." I've never had a problem before.
it is possible that the original "Save Folder" has been deleted or name changed. Go to options and create a new folder to save your photos to. Hope this can help. UAW 974
Jun 25, 2011 | Canon Powershot SX110 IS Digital Camera...
When i try to scan, it gives me the following message "Undefined error occurred. (0x8021001F) A probably cause is that the system is unstable. Reboot the system. If this does not resolve the...
check in your scanner panel if there is any error showing like U 1 or any other message.if not then your scanner is perfect and check your system
Mar 21, 2011 | Fujitsu ScanSnap S510
The cannon DR 2580-C resinstalled to new computer
Capture perfect is scannig software, it is not a driver. You can download driver from this site. http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11360
Install driver and use Captureperfect to scan.
S. Mohan, Chennai, India
Feb 21, 2009 | Canon DR-2580C Path-Through Scanner
My zune software keeps sayin restart after setup
if you have already restarted your computer after the zune install\update... in your program files\zune folder you will find a zero byte ZuneReboot.bin file. Delete it. Start your zune software. try{for(var lastpass_iter=0; lastpass_iter
Dec 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
Memory Problems
The clip can be recovered if you open the temporary directory where Camtasia stores the raw captures in AVI format. The path to the temporary directory can be found by opening the Camtasia Recorder > Tools > Options > Program > Temporary file folder (I'm using v.5 so it may be a little different in other versions).
I've found that there's a certain workflow that seems to work best and you can avoid accidentally erasing your temporary files and having to start your capture session over from the beginning...
  1. Stop Camtasia Recorder - Pressing the Stop button on the Recorder likely won't work, so open the Task Manager (CTRL+ALT+DELETE) and select "CamRecorder.exe" from the Processes tab and click "End Process". Don't open Camtasia Studio right away after doing this step - You'll likely be prompted to recover the recording and in my experience Camtasia hasn't done a very good job at being able to do this successfully and you may end up losing your temp files.
  2. Recover your raw capture files - Navigate to the path where Camtasia stores its Temp files (look above for instructions). Typically, there will be a folder titled "CamCapture{random string of numbers/letters}" - look for a folder with a date modified attribute of the date/time you were working on your project. In that folder, there will likely be several audio and video files as well as an XML data file. The video files will all be 1GB apiece as Camtasia splits the capture into chunks and then pieces them back together to create one continuous file. Cut and paste the files from this folder into a new location outside of the Temp directory. The most important one is the FileWriter{random string}.avi as this is the pieced together file - It will have the largest file size.
  3. Add your media files to the clip bin/timeline - Start a new Camtasia project and import the FileWriter{xxx}.avi clip into the Clip Bin and drag it onto the timeline. Now all of your video/audio should be recovered and available for you to edit. If you have particularly long clips, you may want to check how the audio syncs with the the video towards the end of the clip. If it's messed up at all, you may want to try adding the smaller, chunked recording segments sequentially onto the timeline to see if that helps. If the FileWrite{xxx}.avi clip is good though, you can delete all of the other smaller audio and video clips associated with the capture from your pc to save space - just keep the FileWriter{xxx}.avi clip - the XML can be deleted too.
Good luck - We've had the same trouble here and we use Camtasia almost everyday. In my experience, this seems to happen more frequently when we capture larger dimensions - especially if the capture contains full motion video (as opposed to just screen captures of a product demo or something) and we always seem to have trouble when capturing things that play back FLV or SWF clips at a higher bitrate. This issue is also described in TechSmith's Camtasia knowledge base.
Apr 22, 2008 | TechSmith CAMTASIA STU V1.0 5-9U for PC
Canon 2080C scanner software causing monitor issues
Some sort of feedback through the scanner it seems Delete the scanner software and reinstall. Check Canon website for software updates Consult the Tech support team whilst you are there
May 31, 2007 | Canon DR 2080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
439 people viewed this question
old marine
old marine
