Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Water seeping in dishwasher
Ocassionally clear water will seep into the dishwasher while it isn't running. this in turns leaks out of the door and onto the floor. it's coming up from the drain area. my drain hose is looped above the bottom of the sink. not sure where it is coming from
    Novelist:
  • 166 Answers
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
Why does water seep in when empty?
A defective fill valve could be at fault.
Feb 29, 2016 | Bosch Dishwashers
Water on the floor
Possible that there is leak on the gasket or the drain hose/pump. It is important to take a visual check of the bottom area to confirm the case. If the water seems to seep from the from the front door then the gasket must be checked , please click this link:
Door gasket
Jan 02, 2013 | Dishwashers
Leaks onto the floor
With or without a load in the dishwasher, start the wash cycle and watch the whole thing. Inspect around the door to see if water is seeping through the seal. If no water is leaking around the door, then there may be a cracked hose line somewhere else.
Apr 12, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
Water seeping out of dishwasher from bottom of dishwasher when washer is on. Washes and completes cycle ok, checked hoses and drains already for blockages but none
I assume you are seeing water coming out of the bottom of the door. If this is where it is coming from and the unit is draining okay then your door seal is bad.
If the leak is actually on the bottom of the dishwasher, then you have a crack or seal breach in the cabinet. It is important to find out exactly where the water is leaking from to determine where the problem is located in this circumstance.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Dishwashers
Water seeps out of freezer side of fridg onto the floor, I have totally remover the water line going to the ice maker and it still has water seeping out. It builds up Ice on the bottom of the freezer and...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 25, 2009 | Magic Chef Refrigerators
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Hi, If the drain hose is attached under the sink, make sure that the drain hose is looped higher then the outlet it is attached to.
Most model will hold a small amount of water after draining to keep the seals moist.
I hope this helps.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Dishwashers
GE Side by Side Refrigerator seeping water onto door
Hey, thanks for the photos. Have seen this problem before. Seal the recess area, at the front edge and the front corners, with a little clear silicone, to prevent water from getting behind the stainless steel door panel. I've heard people say to seal the rectangular holes along the bottom side of the door panel recess cut out also, but that shouldn't be necessary, as if you still had water behind the panel, it would just then seep down behind the SS door panel and continue to cause problems. The real cure is to keep water from getting in there in the first place.
May 03, 2009 | GE GSS25QSTSS Stainless Steel
Drips water from bottom left
clean all the door seals there may be some food debris under the door seal at the bottom. also clean off any limescale on the seals also as these can seep water.
Mar 18, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water seeping around fitting on back where water line fastens tp
Where does the water seep from?
The compression fitting you speak of is for the ice maker and through door water (if you have it.).
If water is on the floor, then chances are the drain pan underneath the unit has a hole in it, or for some reason, the water is not getting to the pan.
If water accumulates inside the freezer, check that the tube leading to the pan on the bottom of the refer is not clogged in some way.
If the water is in the refrigerator side, there may be a hole in the tank for the through the door water dispenser. It would leak everytime the icemaker dropped ice and refilled.
Jan 19, 2009 | Amana ARS2464B Side by Side Refrigerator
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
301 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
