Question about E-Machines T6520 PC Desktop
Network problem i have a hispeed internet and the signal from outside is good, modem is ok also. but some times i can not conect to the internet. and network adapter in the sistem propertis have a red cross on it.
    Problem Solver:
  • 12 Answers
This is just a rough attempt at helping you with your problem but if your on wireless and its a built in modem then maybe the modem is not connected right and not communicating with your computer.
Posted on Jul 29, 2008
I cannot get internet on my laptop from an open access point with Time Warner internet
Though you are getting strong signals from the router, the router itself may not be connected to the Internet. The owner may leave the router on but power off the modem. It is possible that they may use the router for thier own private network with no connection to the Internet. When you connect to the router, check your network and sharing center to see if you see an X marked on the connection between the router and the Internet. If you do, the router is not connected to the modem.
Good Luck
C2Solutions
Feb 14, 2012 | Computers & Internet
I have a Motorola SB 5120 modem the P/C light is always flashing .At time I can't get on Wi-Fi from my I Phone or my desk in my sons room, and other time i can.What is going on or do I need another...
Hi
The flashing lights (espicially the Internet light) are normal, they indicate activity (Power, LAN, Broadband, Internet).
Some modems suffer from signal interference from other wireless devices in your home and neighbourhood.
Sometimes the problem may be a signal deadspot in your home to do with unseen metal, pipes, wiring or some other aspect of the buildings architecture.
If your modem has a detachable aerial that crews and unscrews, then it might be possilble to buy a larger more powerful booster aerial for it (take the old aerial to the store with you to ensure compatibilty of the screw fitting) that will give you a better signal.
The modem does not have to be sited near a phone socket. Consider resiting the modem to a good central point where everyone gets a good signal, by buying and using Male to Female power cord extensions and Modem cable extensions.
Ensure that your internet connection is enctypted with a private network key and protected by a password, so that neighbours cannot pirate your internet connection and thus use up your bandwidth and slow down or degrade your signal.
I hope this helps.
Aug 25, 2011 | Arris SURFboard SB5120 Modem
Hi guru, i wish you help me please!! i condigured my wireless router actiontec and i have internet acces in my pc by cable ethernet, but when i try on my laptop by wi-fi or with my celphone, it says that...
Ethernet gives network signals from computer server with connectivity capacities. Once the ethernet is connected to your computer, once of the computers within the network structure has a modem or signal converter box to capture and distibute signals. Your computer is functioning with ethernet cable connection as arranged default. Recent computers however have wiifii capacities meaning that, the modem box is not ncecssary to make signals recognised. Recent computers have builtin signal recepticles, once the programs wireless features are enbled, any available computer networks aer detected. Howver, the wiifii makes connectivity to networks by requesting password keys if the aletrnate computers have protected the entry. Simply said, your computer is ok to function with ethernet as regular achievement. only when the ethernet is malfunct usually caused by the computer that has the modem disconnecting from yours. Your computer should actually get better networking with only one of the method available either ethernet or wiifii. Attempting to receive signals with wiifii and ethernet at the same time impedes the network speed since the structures may only allow an amount of data passage for each network on the same computer. Use the computer wireless buttons located at the system settings area to disable the wiifii until a computer request within your knownlege request to activate wiiffii. Keep in mind that once your wiifii is enabled, another computer is sharing resoruces makign the computer slower if a password was not set.
Feb 04, 2011 | Computers & Internet
Hi, I’m facing one issue with D-Link (DCM-202) Modem from last week. The internet connection frequently disconnecting with interval time less than 10 min. I have checked with service provider COM CAST...
Is this a new issue or a recent harware/cable change or did this use to work and now has the disconnect issues.
Ensure that your cable has NO Splitters (especialy outside) from the Drop outside to your modem.
Check all cableing between Computer and Modem to Cable Drop.
You can also look at the Modem Status Page to check your UpStream and DownStream signals. You may have to have someone come out to check out the line running from your house to the pole (or pedestal if its underground)? Many factors can cause an outside cable to deteriorate, and when that happens you can end up with alot of signal leakage and frequent disconnects. And that goes for both overhead and underground lines. Good Luck, and post back if you need more help. (try to include your Modem Status Logs)
Jan 02, 2011 | D-Link (DCM-202) Modem
Hookin 360 to pc. trying to hook connection to windows media center pc, and home network.
you will need a switch board (network board with multiple ports for with ethernet) and an internet conection. its best to have a router invilved with your modem and so it dosent overheat and shutdown. set it all up and plug you computer into the network board and the consel and you should be good. and make sure to conedt the internet cable in the network to. you need a internet conection to access files from your pc
Dec 15, 2009 | Microsoft Xbox 360 Console
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Jun 27, 2009 | 2wire (1000-400108-001) Router
How to set dsl modem
You go to start menu and access the Control Panel. Open Network Connections and make sure the LAN connection is enabled. If not, right click and select Enable. After confirming LAN connection, then go back a page and click Internet Options. Then the page will automatically show you the General Tab. Type in (or verify) home page in the window. eg. www.aol.com . Then select Connections Tab. Remove any connections that appear in the window below. Below that on the same page, select LAN Settings. Check the Automatically Detect option. This will allow your PC to detect your modem and your internet service. Select OK at the bottom and the window will close. Click Start again and select the Internet Explore. If your internet service is active the window will open to your home page. Good Luck!
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Cant hook up cable internet
You need to contact your isp, they would be able to send test signals to your modem and make sure your modem is functioning properly, then they could help you troubleshoot.
Aug 12, 2008 | Computers & Internet
Internet conection
Modem buying tips Introduction Standards Interface Connection Internet availability .... price if card is a combo card (modem / NIC) or if the card is a ( wireless solution).
Good Luck, Please dont for get to Vote/Thank You.
Dec 17, 2007 | Westell Wirespeed LiteLine 6100...
E-Machines T6520 PC Desktop Logo
27 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
