Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Ricoh Aficio Gets strange IP Address
Hi
I have got an Aficio and it gives me an ip address that looks like this
10.217.142.000.
If i place it on another vlan ex 143 it will get an ip address of ex 10.217.143.22 but not on the 142 vlan.
Can somebody please assist.
It must be in DHCP mode. Do you want to set it to a static IP?
"user tools", "System settings", "Interface settings, "Network", "ip address", highlight "specify", then press the button below "ip add", set your ip, press "ok", then press "ok" again with "specify" highlighted to lock in. Exit user tools.
Posted on Feb 18, 2009
I'm using ricoh aficio 2045e, it's not printing! I think because I don't have the hostname or the ip address and I don't know from where to get it?
Enter in SP mode and print the ALL SMC report .In this report find the IP adress.Enter in your PC printer device the IP adress.
Feb 17, 2013 | Ricoh Aficio 2045e 2035e Copier...
Tip
How to change the IP address on a Ricoh Aficio C811 printer
With the use of a DHCP (Dynamic Host Configuration Protocol) server, you can automate the administration of IP addresses for printers. However, you may want your printer to have a static IP address. To set up a static IP address on a Ricoh Aficio C811 color printer, follow the steps below.
1. When the printer is powered on and ready, press the Menu button.
2. Using the up or down arrows, scroll down through the menu to Host Interface and press OK.
3. Scroll down to Network and press OK.
4. Machine IPv4 Address is the first option on the network menu; click OK when it is highlighted.
5. You will see two options -- Auto-Obtain (DHCP) and Specify, and below them are three tabs -- IP Add., Subnet M, and Gateway. Scroll down so that Specify is highlighted, and then press the arrow button below the left-most tab (IP Add.).
6. Using the up and down arrows to change the numeric value, enter the IP address you want to use for the printer. Use the side arrows to go to the next part of the address once you've entered the value for the current octet.
7. Once you've entered the complete IP address, press OK. (If you want to cancel out without saving the new address, press Escape instead.)
8. If you need to specify a subnet mask and gateway address, you can enter those values in the same way, by selecting each of the corresponding tabs on the IPv4 menu (Subnet M and Gateway, respectively).
9. After you've entered all of the information and saved each address, make sure Specify is highlighted and press OK. You should see "Programmed" displayed on the screen.
10. Turn the machine off and then back on to apply the changes and reset the network connection.
on Mar 17, 2011 | Ricoh Aficio SP C811DN Laser Printer
Change ip address at ricoh aficio 2022
Hi, to change the IP address of a Ricoh Aficio 2022, follow these steps:
- Press the User Tools/Counter button.
- Choose System Settings.
- Choose Interface Settings.
- Choose Network.
- Choose IP Address.
- To specify an IP address, choose Specify, and then enter the address you want to use. To have DHCP automatically assign an IP address, choose Auto-Obtain (DHCP).
- Exit out of the User Tools screen.
Dec 15, 2010 | Ricoh Aficio 2022 Black and White Copier
Hi Guys I hae set up IP address and other network related setting. I can't ping to the printer. Not able to get automatic IP address from the DHCP no ping.
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Hi, we cannot print to the Ricoh Aficio 2022. I have connected to the printer by pinging the IP address of it and it is OK. The 2022 can still photocopy. I have tried a test page and nothing prints.
Are you sure no other device on your network has the same IP address? (Turn the copier off and trying pinging that IP address to make sure.)
Do you have the Ricoh 2022 driver installed? You can download it from Ricoh-USA.com if you don't have it.
Aug 23, 2010 | Ricoh Aficio 2022 Black and White Copier
Finding IP address on ricoh 3260c
If you go into User Tools and select System Settings (or System Features, can't remember which one), there is a tab for Interface settings, and under that tab you should be able to view the IP address.
On some copiers (not sure if the 3260 has it) there is a tab on the bottom of the main Copy screen that says System Status -- if you touch that tab you should see the IP address.
May 29, 2010 | Ricoh Aficio 1018D All-In-One Laser...
Access ip address inofmation page on aficio 3224c
Type the IP address of your machine into your web browser. Login to Administrator Mode as follows:
Username: admin (or possibly "administrator")
Password: (leave blank)
Mar 11, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Aficio 450e installation
First find out the gateway address of your router. Then pick an address for it. If the gateway has an address of 192.168.0.1 then the ip address could be 192.168.0.100. Press the user tools/counter button. Look for IP address in the settings. Usually it is in the interface section. Once that is assigned you don't have to restart the copier.
Once you get that done, then you have to assign an IP address to each machine by creating a port. On the computer that you installled the parallel printer to is a good one to start with. Are you using Vista or Windows XP on your computers?
Dec 15, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
1,973 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
