Question about Canon IMAGERUNNER 6570 Copier
ImageRunner 6570 Stuck on limited functions
We had a paper jam and then a co-worker hit a button saying to run in a limited functions version. And well, now we cannot get out of limited functions and get our finisher to work. Please help!
  • 18 Answers
Press the "Additional Functions" button on the control panel. Press the "copier settings" button. Then scroll through the screens to the fourth or fifth screen (I forget which but you'll find it) and you will see "limited functions" "on" and "off". Press "off", then turn the copier off and then turn it back on again. Your finisher should work now.
Posted on Aug 26, 2008
Sir i have a canon imagerunner 6570 model machine .it was coming an error code .that was e00004-103 . how to clear the error? pls give me a solution as early aspossible thank u srinivas
goto the service mode by pressing (additional function 28 additional function) .in there got to function then to clear and then clear the error by pressing ok and restart the machine
May 22, 2011 | Canon IMAGERUNNER 6570 Copier
Adf shows jam when originals placed in adf. adf was checked, no jam found. also trays 1&2 have 8.5x11 paper in them but show A4. how do I change tray size?
to change the paper size for trays 1,2,4 you need to do this in service mode. to get into service mode hit the additional functions button then the 2&8 at the same time then the additional functions button again.
you should be in service mode.
then hit the copier tab...... options tab ..... then the BODY tab in that setting..... and in that menu there should a CST tab in that menu once there you should see tabs for 1 , 2 , 4 you will need to set the value for 1&2 to 18
that should set them back to letter size. email me if you have problems with it
Jun 05, 2010 | Canon imageRUNNER 5000 Copier
I have a canon copier ir6800 jamming at paper side deck
If the other paper trays work and you use your paper deck more than any other cassette.Your side paper deck tires are worn. You need to replace the 2 pick up tires, the 2 feed tires and the separation roller. Hope that helps.
Apr 21, 2010 | Canon IMAGERUNNER 6570 Copier
Printer says paper jam when there is no paper jam hit the ok button and it will print out a paer fine and then say paper jam again. repeat
the rollers that feed the paper into the machine have a a set time limit to do so... if the rollers cann't do it in this time limit then you get a paper jam. you either need to clean the rollers with isopropyl alcohol (rubbing alcohol ) and a rag or replace the rollers...
Dec 29, 2009 | Lexmark T644 Laser Printer
Paper jam left sided output rollers - ImageRunner 1330 can not see how to get into to pull it out. Lost users manual forever ago.
Those output rollers are at the exit to the fixing assembly. They wear and become dirty, causing copies to stick and 'concertina'/fold up around the rollers.
You need to have the fixing assembly replaced. Have this done professionally, or you'll end up with a fire or an electric shock.
Oct 03, 2008 | Canon IMAGERUNNER 6570 Copier
Paper Jam
Did you open the smaal door on the lower left to try to remove it from there.Or is it stucked in the fixing area.
Jun 07, 2008 | Canon IMAGERUNNER 6570 Copier
Paper jams when using staple option for more than 13 copies
There is someting I would like you do for me, I will tell you how to enter service mode and retrieve a jam code, give me that jam code, I will look it up and tell you what it refers to and what it could be.
1) Start service mode. (Press the '*' (additional functions)key, '2' and '8' at the same time, and the * key once again.)
Press the copier tab > then down the left side select jam
You will see Date, Time 1, Time 2, L, Code, P, CNTR and Size.
Write down the last 5 jam codes, eg. 0201 or 0112, OF12, 0014 whet ever the combination, if you can take down the date, two times, cntr and size, would be helpful also.
Do not go changing other settings in service mode as you can seriously affect your copier and you will end up calling a tech anyway.
Please get back to me with the codes.
May 28, 2008 | Canon IMAGERUNNER 6570 Copier
My cannon super 63 image runner 1370f
look on the control panel if there is a diagram of your printer it will usually light up the area where the paper jam is located.
once you find location of paper jam there is normally a green knob in the area of jam that when you manually rotate it will release paper also open paper drawer check for jam or unplug and plug copier back in somtimes this will force paper out as it resets
Jan 13, 2008 | Canon IMAGERUNNER 6570 Copier
CANNON SUPER 63 IMAGE RUNNER 1370F PAPER JAM
It is hard to tell where the paper is with out seeing it or looking at the jam log. start by looking for green. On canon green is for jam removel if you see a green tab lift it, if you see a green knob turn it. good luck
Jan 12, 2008 | Canon IMAGERUNNER 6570 Copier
146 people viewed this question
old marine
old marine
