Question about Olevia LT32HVM 32 in. LCD Television
No cable signal on 32" flat panel Olevia tv
After a severe electrical storm in the area, we have a tv that no longer works with a standard coax cable connected. I have tried the same tv using a dvr cable box, connected via standard HD cables and the tv works fine. I Also tried using my Xbox360, with HDMI cables, and that also worked fine.
I think I've narrowed the problem down to a connection issue between the tv tuner and the coax cable connection in the wall. Any idea's on what may have happened?
  • 1 more comment
  • abowling68 Aug 19, 2008
    Having same problem. Plugged into surge protector had power surge from power lines and now tv will not work from cable coax but will work with other inputs. such as hdmi, red yellow and white cables used with cable from wall going to vcr.
  • Anonymous Sep 26, 2008
    42;ljk;lk;lk;kl;mm
  • Anonymous Mar 24, 2014
    What type of cable will connect my tv to a laptop?
  • Olevia Master
  • 5,568 Answers
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Posted on Aug 02, 2008
Connect my Olevia 323 with the signal if there is no coax input at the tv??
HAHAHA not possible it has to have a coax either from an antenna or a cable provider . unless you only plan to use as a dvd monitor
Jan 28, 2015 | Olevia Televison & Video
Get "no signal" with coax
Check the input selection on the TV, it maybe set incorrectly.
Jan 22, 2011 | Olevia 237T 37 in. LCD TV
47 inch Olevia plugged directly into cable no box and will not program. All other old cable ready tv sets work without box
Diffrent tv,diffrent signals,deffrent frequencies.Talk to ur cable company for the box,to many pay tv signals in one area this day,that why need a box.
Nov 05, 2009 | Olevia LT42HVi 42 in. LCD Television
When hooking my direct tv into the coaxl in it does not work ? When I use the AV cables it works. and I do try all inputs.What can I do
If the coax RF OUTPUT cable of the direct TV BOX is set to channel 3, the the TV will have to be SET TO TV CH3.
Nov 02, 2009 | Olevia LT32HVM 32 in. LCD Television
My TV says NO SIGNAL on tuner...
yes, you may be lucky to just to burnt one of the source/input mode try switching them.
for example use a video cable instead a coax if you still dont get a signal that means the picture uotput board is damage by the storm.
Aug 15, 2009 | Olevia 227-S11 27 in. LCD TV
I can not get my Olevia 32' tv to show cable. Does
what input do i put my tv on to get a picture it says no signal
Aug 09, 2009 | Olevia Televison & Video
TV tuner
Bill, did your tuner go out? I have had the same television for one year. We had a storm and our Buckeye cable went out. All the other tvs came back fine except for the room with the Olevia 232-S12. Everything works now except for the tuner. Cable came in and installed a converter box. Just wondered if you had the same problem (not the storm, but the tuner)
Jan 08, 2008 | Olevia LT32HVM 32 in. LCD Television
Olevia LCD 32 inch
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Oct 12, 2007 | Olevia LT32HVM 32 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
421 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
