Question about Hitachi Director's Series 65XWX20B 65" Rear Projection Television
HITACHI 65XWX20B - How to disassemble the cabinet?
I have a Hitachi 65XWX20B 65 inch rear projection tv, I simply want to move it into the den, but it's too bulky to be able to turn it around in the hallway to get it into the door. I'd like to dis-assemble the cabinet so that I can move it in pieces. Anyone know how to open the cabinet...I unscrewed all the screws...nothing budges. If I could just get the bulgy back end separated from the rest of the cabinet then I think I would be OK. Has anyone done this, or does anyone have the service manual?
  • dalascby Aug 11, 2008
    Thanks for the info. Tell me, what are the potential issues with turning the TV on it's side? I don't think I'm going to have any choice but to turn it on it's side in order to get it into the room, in it's upright position I cannot turn it enough to get it into the doorway (it's a room thats along a hallway...the TV is much wider than the hallway).
    Thanks
  • patparsons1 Nov 24, 2008
    I have a similar problem with a Mitsubishi VS-60609 60 inch tv. Can the same be done with this tv??
The 65XWX20B comes apart in 2 pieces - there is a top half and a bottom half.
- The bottom half houses all of the electronics, projection lenses, etc. It is very heavy and should be moved with care.
- The top half is basically just the screen.
I have moved this Television multiple times, even up and down from a 3rd floor apartment!
- First remove the screws holding the top and the bottom, the important ones are on the sides of the TV.
- This is important, I suggest 3 people do this part: Slowly lift the top away from the bottom half of the TV, but -not- very far. There is small wiring harness that that attaches the top of the TV to the bottom to a circuit board. This must be unplugged by one person while the other 2 hold the top half of the TV slightly above the bottom half. Note carefully where this plugs in so that you can reassemble easily.
- Once this is disconnected the TV is much easier to move, although still quite heavy and bulky. Do not turn the TV on its side - keep it upright while moving.
Reverse this process to put it back together.
Once you have done it once it is quite easy.
Good luck.
Posted on Aug 10, 2008
Where is the projection bulb on my Hitachi 65s700 65 inch
Hi Anonymous,
There is no "Projection Bulb" for this model. It as a 3 tube Rear Projection TV. The most common problem is Convergence Failure as in the link below.
Calgary Hitachi Big Screen In Home TV Repair Service
Robert
Nov 12, 2015 | Hitachi Televison & Video
Blue power light flashing and no picture
You have problem with y sus on tv. Please fix it or replace with new one.
Regards
Feb 01, 2011 | Hitachi Director's Series 65XWX20B 65"...
I have a 65 inch Hitachi HDTV. There are red,
Sounds like you need to purchase a convergence kit. Instuctions are included
Jul 21, 2010 | Hitachi 43UWX10B 43" Rear Projection...
My 6 year old 65xwx20b tv convergence problem
Good Day,
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, www.bdent.com and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Needs convergence IC's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Good Luck,BIG IRISH.
Nov 23, 2009 | Hitachi Director's Series 65XWX20B 65"...
Can't get manual conf. to hold in white
Ur convergence it dead.need it to be replaced,know how to solders?Tries these Websites for convergence kit.Tv repair World.com or Tv repair Kits.
Nov 18, 2009 | Hitachi Director's Series 65XWX20B 65"...
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Hitachi 65xwx20b
hello. yes you might check the cord . ? or your outlet that your pluging in to,might not work.? check them. ok hope this help's you."GOOD LUCK"
May 03, 2008 | Hitachi 50UX58B 50" Rear Projection...
Loss of Green Color
Check the green Crt PCB circuit for bad solder if the solder looks good check the green drive transistor located on that same PCB.
Let me know if you need further assistance.
Jan 08, 2008 | Hitachi Director's Series 65XWX20B 65"...
Hitachi Director's Series 65XWX20B 65" Rear Projection Television Logo
1,232 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
