Question about Sony FD Trinitron WEGA KV-36FS320 36" TV
Sony kv-36fs320 red light continues to flash on the front of the tv. cannot turn tv on with the remote control or front panel. tried disconnecting and re-connecting, Thanks,
  • cpanycny Dec 31, 2008
    I have the same exact problem, cannot turn on
9 flashes
Thanks Dan.
Posted on Oct 26, 2008
  • 4,234 Answers
The flashing should be a repeated count with a 2 or 3 second pause between the counts. Can you post the count here please. That will indicate the problem circuit and allow me to give you more details on how to resolve the problem.
Thanks,
Dan
Posted on Jul 29, 2008
My tv won't turn on and the Standby light keeps flashing
Check your remote control.
Try using the TV front panel. If working OK, check your remote unit battery.
Sep 08, 2010 | Sony KV-27V66 27" TV
The stand by timer light on the front panel is flashing red why? and how to stop?
This is because there is some internal problem in the TV.
try pressing the POWER button on your remote control or on the TVfront panel.
If the problem persists, see “Contacting Sony“ at the
end of this section.
Thanx
Jul 28, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Sony kv-36fs320
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Sep 21, 2008 | Sony FD Trinitron WEGA KV-36FS320 36" TV
36 inch wega trinitron
If a red light flashes for more than a few minutes,disconnect and reconnect the power cord.
Check the TV/VIDEO settings
make sure you have inserted the batteries correctly to remote control.
Try another channel to rule out of station trouble.
if the problem continues may be a power supply problem.
good luck ! please dont forget to vote if this suggestion is helpfull.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Cannot turn tv on!
hello, you do have a horrizontal problem, you may have a short parts on the said section, shorted horrizontal output transistor can couse this indicator to blink. when a shorted transistor then you may have a defective FBT. try to check some parts. ty
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Sony Wega KV MOdel
hello, you may have a manual switch botton problem, check those volume control switch, do some test, check the board for some cold solder or short connection. ty
Nov 19, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Sony KV-32FS200
I read the manual and it says in the FAQ.
Q- TV doesn’t turn on
after disconnecting
the TV and timer
LED flashes
❏ Press the POWER button on your remote control or in the TV front
panel, one more time.
Tell me if it works...
Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Jun 27, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony FD Trinitron WEGA KV-36FS320 36" TV Logo
149 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
