Question about Panasonic PT-51HX41 51" Rear Projection Television
Need PT-51HX41E Service Manual
Need Panasonic PT-51HX41E Service Manual, please help
  • Anonymous Nov 29, 2008
    i have the same problem
  • JAY4REAL4 Jan 11, 2009
    MY PANASONIC PT-51X41E 51in REAR PROJECTION WON'T COME ON AT ALL ?
    Problem Solver:
  • 14 Answers
    Problem Solver:
  • 9 Answers
E-mail ipbass@gmail.com, I have the diagram PT-51HX40B,
Posted on Aug 30, 2008
I have a Panasonic PT-51HX41E, and it will not power on.
does the power light blink? If so thats an error code let me know the number of blinks and I will assist you with the issue.
Feb 06, 2013 | Televison & Video
I have a panasonic PT-51HX41E 52" projection tv
A tech might be able to get into the hidden tech menu---sub brightness and sub contrast settings are there and it is not real easy to get into and does vary from model to model---access is with the original remote.
A suggestion if you can not or do not want to pay would be to search with Google and the model number for a "Service Manual" which will in it have instructions and indicate how, it will also have a list of items in that menu---be careful what you adjust there.
Dec 14, 2012 | Televison & Video
Greeting: I have a panasonic PT-51HX41E tv and when I turn the Imaje is hard like 3 seconds and off. Then unplug and re-provided plug and turn on and does the same,thanks for your help.....
Look to see if sets power light blinks a sequence after it shuts off. The most common on this model is a series of either three OR five blinks.
Let me know what you find and I will assist you.
SD TECH
May 17, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Remote control programming code
you can look up all the different codes in the remote manual. if you do not have that look up the codes for the brand of remote online or turn on the set and put the remote in the aearch mode and you might be able to find it that way. kind of dificult to tell you without the brand of remote you have!
techman
May 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic pt-51hx41e will turn on for couple secs then turn off
hello. it sound like a power supply problem.!!! to me .!!! you can check it frist.!!!"good luck"
Aug 01, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt51sx60a ,bottom of picture bowed color has shadowy hues of blue ,occasional warping of picture ,hard to watch
my tv is panasonic pt-51hx41e hay can see picture but come on disturtion in tv ,they side that is mother board $380.00 hay need to now is true,or hay can buy part and ware?
Jul 30, 2008 | Televison & Video
PANASONIC PT-51HX41E
The convergence amps have most likely failed. That unit takes two STK392-110 (Sanyo) amps. For more reliability I'd have them changed using an STK392-150. They have a greater amperage and higher heat tolerance.
It's clearly a job that you want a qualified shop to do.. Call around and get some off-the-cuff estimates on what they charge to change out the convergence amps and tell them that you would prefer they use the 150's instead of the 110's.. They'll probably wonder how qualified you are. :)
Bill
Nov 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt-51hx41e tv screen codes
I found this on the net let me know if this works for you Once you are in service moce on a Panasonic you must continue through all steps to the end to exit. It starts with the B parameters, then C, S, and M, then you can exit by pressing power and action ON THR RECIEVER for 2 seconds. The TV will turn off and come back on on ch3 with sound. BTW, you advance thru the menus by pressing power on the remote.
Oct 05, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Service Manual PT-51HX41E Needed?
If you haven't the technical ability to repair this set I suggest to get a tech to replace the stk392-110 convergance amp ic's. these ic's are very noticable they have the largest heat sinks in all the sets ic's. but the problem may not be the ic's alone, there may be several resistors open or open pico fuses. So if you are not technicaly inclined donot attempt this repair. it's not just the replacement of the ic's that need be done but geometry and final convergance in the service menu. please leave this to the pros.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Broke reflection mirror
I would just replace the mirror part# TKG2AA50051 (about $115).I would not try to substitute an ordinary mirror.
Sep 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
877 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
