Question about Toshiba e-Studio 350 Copier
Print Data light blinking
When I attempt to print a PDF file, only the first page prints. Then, the Print Data light begins blinking and freezes up the copier. I have to turn off the printer to reset it. What's going on, and how can I print all pages?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
-try converting the PDF file
-the driver may need to be reloaded
if you print from Word does it go trough? if yes then that particular file is the problem
Posted on Aug 12, 2008
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
When I go to print a pdf file, it takes forever to begin. THe pdf-viewing software displays a progress bar showing the status of each page as it is "prepared" for printing.
I would try to set printing option to "Print As Image". From the Adobe Reader, you would like to click "File" then "Print" then click "Advanced" tab, and select a check mark on the "Print as Image".
Then click "OK" and "OK" to print the pdf file.
Hope this helps
Mar 30, 2011 | Samsung ML-2510 Laser Printer
Epson Stylus T10 printer prints out random symbols from PDF file
When you attempt to print, make sure you are using the correct printer. If you had an old printer before, its name will be still in the printers' list.
and unknowingly you may be trying to print with that printer. To check this:
Goto the File Menu -> select Print-> Highlight the printer you are currently using, and then Print.
I am pretty sure this will solveyour problem.
If it does, give a rating to this answer.
Have a good day.
luciana44
Jan 06, 2010 | Epson Office Equipment & Supplies
PRINTING WINGDINGS WHEN I PRINT PDF FILES
Adobe PDF reader tends to print webdings/wingdings in its version 8 incarnation. Download FOXIT reader free from filehippo.com and try to print your document from that instead of Adobe. This nearly always fixes the problem. antosarmy
Nov 25, 2009 | HP DeskJet 5550 InkJet Printer
HP OfficeJet 7680 will not print pdf files.
Put an Acrobat Reader to read your PDF, like version 8 or latest 9. To open a PDF is only an Acrobat Reader and can print also in it.
PDF file format are made and construct by an Adobe Professional software and have a realiable to save as your file into PDF, WORD & etc.
Jul 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
Wont Print a Large PDF File
You don't say what kind of printer or computer so it's a little hard to narrow down what is happening. That said, it sounds like you've running out of disk space while the print driver is trying to make data to send to the printer. If you can print the 1st few pages (try 4, then 3, etc.) then this is almost certainly happening.
Check how much free space is available on your hard drive.
Carl
Dec 09, 2008 | Office Equipment & Supplies
Printing PDF files
I had this problem after I had fixed a problem printing from Quicken. I was able to print from Quicken by changing the print option in Windows -- mine was set to "Spool documents" and I changed it to "Print directly from printer" -- the advice I was given was to change it from whatever it was set at to the other option. For printing a PDF file, I changed it back to "Spool documents" and it allowed me to print the PDF file. Try this and see if it works for you -- click the Windows Start button and select Settings, then Printers and Faxes. Right click on the selected printer and select Properties. In the properties window look for a setting to print directly to printer or spool documents -- mine was under the Advanced option. Try the option not currently selected -- in my case, I changed it back to Spool documents with Begin printing immediately -- and then try to print a PDF file. It looks like I will have to toggle back and forth when I am printing from Quicken and when I am printing a PDF file. Hope this works for you.
Mar 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
Toshiba e-Studio 350 Copier Logo
1,150 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
