Question about Mitac Mio P550 GPS Receiver
Mio P550 When I try to use mio map to find any address. I am getting the following message in a pop up: "Exception occured Callstack dumped to \crash.txt" when I click ok on the popup. I got another message: "A problem has occured with gwes.exe." Could any one help me out to resolve the issue. farhanislam1@hotmail.com
  • farhanislam1 Jul 30, 2008
    I dont know how to sync Mio P550 with my laptop. I have Vista in my laptop. Sync program is not working.
  • farhanislam1 Jul 31, 2008
    thank you for your help. I could set up Active sync in Visa. Ever thing seems okay but the problem is:
    Active syns is using Windows Media player as a default program for Sync. By this it only opens media files. While I want to see all files in my GPS. not ony media files. Could I set up Active sync to use windows explorer, then I will be able to see all files in my gps.
    Problem Solver:
  • 5 Answers
why not go and read crash.txt?
Or, just install MioMap once again?
Posted on Jul 30, 2008
  • katyak Jul 31, 2008
    I would 1)read Help on Sync in Vista (though I gather Help is rather difficult to obtain) or try to directly open Mobile Device;
    1a)try to fix firewall issues- it's called something like Windows Defender- tell it the device is OK;
    2) install an older version of Active Sync, like 4.1
    3)there are a couple of other ideas, but may be those will work for you already
    Best
    Well it seems a bit weird. Active Sync uses Media player to sync the media files, but not anything else (be it understood that I prefer Win XP pro to Vista and get very angry with it when trying to do some simple things).
    An ad-hoc solution might be to go to Media Player and tell it not to sync with portable devices, another to install th Ac Sync 4.1 (not sure it'll work for Vista), yet the third one to hit the help on Microsoft site.
    If none of the above works, to install in a separate partition Win XP Home and sync through it (consuming). There is also a magasine called something like "Windows" which responds to questions of this sort.
    Quote" if nothing works, will you consider reading the instructions?"-very old (1975) joke
    Never mind,
    Best
My gps need install windows ce but install because I connect the cable to the computer but the computer gives unknown device message
If you GPS is at the point of needing windows CE installed then it is in a bad way. This is not done in the normal way on the Mitac Mio. It is setup using and SD cardspecific keys assigned by mitac to perform only a minimum of functions for its GPS hardware.LikeRESET +POWER then selecting different options specific to the GPS
Then getting maps on it is also different from a straight install. I suggest you contact MIO and have them reinstall Win CE and the maps for you before you compromise it totally so that it cannot be undone
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Mitac Mio P550 GPS Receiver
MIO P550
oprn that folder and there you find the licence detail and fill in the licence detail and then turn off and turn on device and it will be done.
Dec 05, 2007 | Mitac Mio P550 GPS Receiver
Mio P550 how to change hardware id
Do a hard reset. Pull batt. let stand for 30 min or more.
Can't put Mio P560 in bootloader mode
up arrow + power_on until MIO logo
Feb 07, 2010 | Mitac Mio P550 Pocket PC
How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from www.microsoft.com and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
Aug 08, 2009 | Mitac Mio P550 Pocket PC
File format error
search on the internet for other file, because yours is broken. After you have it, overwrite the old file.
You can try http://rapidlibrary.com/index.php?q=canada+fbl+maps
Apr 08, 2009 | Mitac Mio P550 GPS Receiver
Mio p550 not recocnized sd cards
Try this : Open your device ( it have 5 screws). Inside next to the sd card reader are two metallic sponges. Take them off ( they are glued on some electronic parts and it's shorting the circuits)
Mar 13, 2009 | Mitac Mio P550 GPS Receiver
Mio P550 reboots but does not take any touchscreen inputs
I had the same and contacted MIO (use the phone number for your country,
http://www.mio-tech.be/EN/support/support-overview.php
). It was related to the shock the screen got and they graciously changed it for me (it was during the second year of the warranty). If the warranty has expired, you are probably looking to about a hundred bucks expense.
Courage,
Jul 02, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 how do i do a hard reset
on/off switch in "off" position for at least 30 seconds, then turn it in "on " position, power on and "reset". You'll lose all your data and all the installed programs.
Alternative: using the screen options, go to "system info", and choose "hard reset".
Beware: pushing the joystick down while doing a reset will get you a boot menu with memory-formatting options. Choose "exit".
Otherwise look into xdadevelopers forum (Google it or go to, say,
Mio P550 / P350 ROM upload [Archive] - xda-developers
A good idea would be to backup your data in the first place- just a hint.
Enjoy.
Dec 09, 2007 | Mitac Mio P550 GPS Receiver
Mio p550
I dont know about the charges but did you "format" the card?
Jul 01, 2007 | Mitac Mio P550 GPS Receiver
Mitac Mio  P550 GPS Receiver Logo
784 people viewed this question
Top Mitac GPS Experts
Simon Flummox
Simon Flummox
Greg Cann
Greg Cann
Are you a Mitac GPS Expert? Answer questions, earn points and help others
