Net gear WG311v3
It stays on scanning and it shows no signal. the light in the back of my computer for the wireless is not on
Please i need a ethernet conroler driver for hp compaq dx2290 window xp
Posted on Aug 05, 2008
  • david bright Aug 05, 2008
    please i need a ethernet controler driver for hp compaq dx2290 window xp
I need a driver for Netgear WG311v3 802.11g Wireless PCI Adapter for Windows 7 32bit
You can try downloading from this link:
http://netgear-wg311v3-802-11g-wireless-pci-adapter.soft32.com/
Nov 14, 2012 | NetGear WG311v3 802.11g Wireless PCI...
I need drivers for net gear wireless pci adopter wg311v3
click here to download the drivers....
good luck...
Please rate the solution, write a testimonial if you like the service....
May 23, 2011 | NetGear - WG311 - 54Mbps 802.11g/b...
I have not used my laptop for a while and when i came to use it my wireless connection wont work i have a netgear virgin system installed.
Check in the device manager if your computer is seeing the wireless card driver.
Right click my computer, properties, hardware, device manager,network adapters.
Is the wireless card listed?
If it is right click uninstall and reboot on reboot the wireless card should be seen as new hardware follow the wizard and let it install the driver.
If the computer is seeing the card but it has a yellow mark next to it the driver is not loaded you need to get the appropriate driver for that type of card from it's support site or once again try the uninstall reboot.
That’s the wireless card.
Is the net-gear showing an internet connection.
Put a cat 5 cable from your laptop to the net-gear and try to connect via cable if that works it's got to be the wireless card driver or the wireless settings in the net-gear however if they worked previously there is no reason to suspect the router settings.
Hope this helps
Sep 12, 2010 | Computers & Internet
SMC2804WBR router: The lights are on but nobody's home.
Sounds like the router is about to die. I had the same issue with a wireless router a few years ago. It would broadcast but I would not be able to get onto the wireless no matter what I did but plugging straight into the modem and it worked just fine. If you've done a hard reset and it is still not connecting or staying connected, it is about time to replace the router.
Nov 17, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Start up and Signal problems. need to download WGT624 set up
.chk files are normally those produced by the system after a hard drive repair or some such, and shows lost clusters on your drive.
Your Broadband modem feeds the router (your problem device), which in turn connects to the computer's Network Card, the one with the RJ45 connector. The smaller connector goes to your modem, for use with Dial-up signals, not broadband. Cable modem feeds router, router routs signals to various computers, via RJ45 cables. Your router is probably for 802.11g signals, used by the majority of networked computers. The 311 in your computer plugs in to the 624 router. They work together to get you on the Internet.
Nov 07, 2009 | NetGear WGT624 Wireless Router
NETGEAR WG311v3 Wireless PCI adapter STUCK on scanning.
Hi
What you to do first verify that the device is installed properly for that ---
Go to Device manager-- click on Network adaptors -verify the your wireless adaptor is listed there without any yellow or red mark .If you see a yellow mark then you need to install and reinstall the adaptor
Second , You might see an icon for netgear adpaptor in right lower corner under taskbar and you need to Right Click on it , it will show you several options just look for use window to manage wifi or xp wifi client , like that .. sect that option ..
after that it will display a message wireless network detected , click on the messege , you will see your network . select and connect
Mar 29, 2009 | Computers & Internet
Laptop wireless internet connectivity
use the zyxel you have best range and good signal also otherwise you take a acces point and you get it the best of the best link and signal
Jun 10, 2008 | NetGear (IM-WG511T) Wireless Adapter
Psp set up
You need a wireless access point to connect PSP thru
infrastructure mode. If there's none available, the
wireless network id will not show. Scanning the network will
let you know if there's a strong or weak signal (%).
Just use the scanned id that shows up in the box.
You can change the name to whatever you like by editing it.
Mar 19, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
