If you are reacting to this product, stop using it and find one for sensitive skin.
1. First tip
is to lift your arm straight above your head as this pulls the skin tight and
helps you reach difficult hairs that might be hiding.
2. Shave
your arms in up, down and sideways motions for the smoothest results.
3. Finish by
rinsing with cold water and this will close your pores.
1. Make sure
you use a moisturizer before you start shaving
2. Pull the
skin tight to create tension.
3. Shave in
the direction that the hair grows
4. If you have a beach or pool day out, make sure you shave the night before to avoid rashes and irritation from shaving.
There are Medicated Herbal Oils. Try Indian or Sri Lankan Hair Oils. You may search on Web please.
