Question about Vivitar ViviCam 3785 Digital Camera
Battery Do you have to use the rechargeable batteries in the camera or will and double a batteries work?
  • 89 Answers
Either of the two will work.. it is better if it is a rechargeable battery since you can use it several times unlike a regular battery that you can only use it once.
Posted on Aug 25, 2008
Won't turn on,even with new battery. Turned on the first time,but 2 weeks later it won't,even charging battery again. Hardly had any use since new, appro 3 years old.
More likely to be a battery issue than the camera.
Do the batteries work in another device? They may have just deteriorated with age or being left uncharged.
Are you sure they are rechargeable batteries?
Try replacing them , even with cheap generic batteries if they are AA/AAA just to verify the camera works.
Double check you have them oriented correctly when putting them in.
Aug 09, 2015 | Nikon Coolpix S2500 12mp Digital Camera...
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
My Polaroid i1237 Camera Has A Low Battery. They Require Alkine Batters [Double A). I Have The USB Cord, Wris Strap, and an Extra Memory Card. The Battery Is Lowwww, So Do I charge MY Camera With The USB...
Alkaline batteries are not rechargeable...in fact, it would be dangerous to try to charge them. You can purchase rechargeable NiMH AA batteries that come with their own charger. This will save you a lot of money in the future.
Jan 07, 2011 | Polaroid i1237 Digital Camera
Whenever I put batteries in the camera it won't turn on but if I use an AC adapter it works just fine. I've tried Heavy Duty, Alkaline, Lithium, and even Rechargable. The battery door is fine and intact.
The manual indicates that the camera should be able to use either alkaline or rechargeable AA size batteries.
Make sure that you are observing proper polarity of the battery as they are installed. Also double check the battery door. There should be 2 small metal strips that make contact with the batteries as well.
If polarity is being observed (see manual to double check), and the metal strips are both present, then it is likely that one of the contacts on the battery door or inside the camera are corroded, or perhaps broken. In either case, contact Minolta for repair assistance, or battery door replacement.
Jun 22, 2010 | Konica Minolta DiMAGE Z2 Digital Camera
I have a Sony Cybershot DSC-W5 5.1MP - purchased about four and half years ago (ancient in technology years I know) - but it's a good camera and has served me well. For about six months I've had issues...
Have you tried this technique? Rub the contacts in the battery compartment with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Dec 29, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
My camera wont turn on at all and its brand new
Double check the batteries and make sure they are inserted correctly.
If the battery is rechargable, recharge the battery and try again.
Mar 05, 2009 | Nikon Coolpix 4300 Digital Camera
Sp 350 battery
It Needs a Lithium battery- only lithiums have the density to cope with the demand - no need to buy expensive Olympus Originals
Try www.sevendayshop.com for starters
Plenty  of sellers out there.
Oct 14, 2007 | Olympus SP-350 Digital Camera
Rechargable Battery Problem on Kodak DX 4530
Inside the battery compartment, on the same side as the battery cover hinge, you will see a small white mechanism. As I understand it, this is a microswitch which recognises when rechargeable batterys are installed. I suspect this may have been damaged. If so, you will need a rock-steady hand and brilliant eyesight to repair it. Even dismantling the camera is a challenge.
docramage
Oct 06, 2007 | Kodak EasyShare DX4530 Digital Camera
Rechargeable Batteries
This is a triky one. Most cameras will work with rechargeable batteries. If they don't work the most probable cause is this: a normal battery has about 1.5 V nominal charge. Because you use 2 of them you get 3 V nominal charge. Most rechargeable batteries have about 1.21 - 1.25 V like yours. This is given by the technology type used in their construction. However 2 1.25V batteries will result in 2.50 V at nominal charge and some cameras woun't go whell with the 0.5 V difference. You should try other types of rechargeable batteries, maybe some of them will work, but it is recomandable to do that before you buy them, so like I said, it's a triky choice. Try to go to a digital camera shop, they may sell rechargeable batteries more compatible with your camera.
Mar 11, 2007 | Fuji FinePix A500 Digital Camera
Vivitar ViviCam 3785 Digital Camera Logo
16 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
