Question about Refrigerators
How to check and see if thermostat is stuck
Freezer gets cold but the refrigerator don't. My husband noticed that on the outside of the freezer door on the bottom it gets very hot to the touch. He thinks the timer is working correctly. Do you have any idea what he needs to check next.
    President:
  • 1,462 Answers
I am assumiong this is frost free type
take rear panel off inside freezer and check if the pipework is iced up.
if so, switch off and melt ice off with a hairdryer.
if fault reoccurs, you have a fault with the defrost system and get back to me
doug
Posted on Jul 31, 2008
Freezer working fine, fridge not at all
Brand name and model would help but here is a guess. Most frost free refrigerators have the main cooling unit in the freezer area side. To get the fresh food side cold, there is a small fan in the freezer side that blows cold air to the fresh food side through a duct work or trap door. If that fan stops or fails for and reason, the first place you will notice the temp rise is in the fresh food section. See if you can hear the freezer fan running. You may need to push in the door switch for the freezer light to hear the fan because they sometimes run the fan wiring through the door switch. It may stop when door is opened.
Apr 03, 2015 | Refrigerators
Frost in top freezer - water leaking in refrigerator - ice maker not working
go through this link it will help you
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Oct 08, 2008 | Frigidaire FRT21HS6D Top Freezer...
We own a 15 year old Maytag Plus, model #RSW2700, side-by-side refrigerator. Several months ago it was leaking water onto the floor. Additionally the outside of the refrigerator, freezer side, was very...
Hello, first thing that you would check would be to remove this panel numbered 28 on this diagram click here http://c.searspartsdirect.com/lis_png/PLDM/X2902579-00004.png
following your removal of the panel then you would have access to the evaporator drain coil. If you noticed any icebuild up on the drain coil this would first have to be defrosted using a hair dryer due to this is termed as a defrost issue whereas either the defrost thermostat, the defrost heater, the defrost timer or the adaptive control would have a fault and have to be tested. If you do see the ice build up message me back and I will instruct you how to test. The next area that you would look at behind that same panel is the evaporator fan motor which is part number 16 on the same diagram if there is no air flowing from this fan then the air cannot go into the refrigerator side of the unit. If the fan is working and you have no ice build up on the evaporator you would then go to the inside rear wall of the refrigerator click this link http://c.searspartsdirect.com/lis_png/PLDM/X2902579-00002.png notice parts 12,13 these parts mainly 12 is the freezer damper it is a small door that is supposed to open and close letting the cold air from the freezer side of the unit into the refrigerator side of the unit. Assure that there is no ice build up on the damper door and that the door does open and close easily and is not stuck in the closed position. This damper control is located in the ceiling of the refrgierator which is part 5 on the diagram as well. If you also unscrew that entire panel that is on the ceiling is how you would access the control which is attached to the knob that you turn the refrigerator to become colder. Check to see that the fan is working in your freezer and to see if you have any ice build up first and then message me back. Also If you have any questions message me those back as well. I await your reply. Thanks
Rick
Sep 25, 2011 | Refrigerators
Freezer runs continualy. Temp stays at 16 degres F. at all thermostat settings. Outside door skin seems very cold..
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 17, 2010 | Refrigerators
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Doesnt get cold??
Okay,
Defective compressor, refrigerant low from a leak in the system, dirty condenser coils, condenser fan not working, bad compressor relay or capacitor, main thermostat control not working, thermostat needs to be set at proper setting, frozen evaporator coils do to faulty defrost timer, defrost heater coil broken, or the defrost determination thermostat has stayed in the open position, which would result in no defrost and the ice blockage would stop air the circulation, defective evaporator fan, defective door switch which controls the evaporator fan when one opens and closes the freezer door. Freezer drain clogged which would possibly cause the fan to be stuck because of ice built up around it.
Oct 13, 2009 | LG LFX25971ST Bottom Freezer French Door...
Freezer has been warmer than normal lately
check the door beeding which make seal between the body and door.Clean with mild cold water and check it is sealing properly while it is closed.check the compresor ,it should be light warm not hot.
Jun 03, 2009 | Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Refridgerator/Freezer will not get cold
Check to see if the refrigerator is clean at the condensor at the bottom or at the top of the unit. All fans running inside and outside the unit? Door gaskets sealing tightly. Put a dollar bill between the door gasket and cabinet and clost the door. Slight drag ok. No rsistane, bad gasket. No solution at this point, call for service.
May 04, 2008 | Magic Chef CTF2125 Top Freezer...
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
