Question about Whirlpool Calypso GVW9959K Top Load Washer
Nothing works but I have power
None of the buttons work on the front of my Calypso. I checked to make sure it has power and it does. All of a sudden it started working yesterday and now it's doing the dame thing again. Nothing lights up not the time display or the button lights nothing. It's like there is no power to it at all.
    Novelist:
    Champion:
  • 261 Answers
I would unscrew the console and check the serial cable from the user panel to the ccu by unplugging and reconnecting then try again. If not the touch pad needs to be replaced.
Posted on Sep 07, 2008
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My Kenmore Calypso washing machine has is
Where the power cord goes into the washer is a small box called a line filter. It is there to protect the electronics in the control. It might be that the line voltage filter has failed. Remove the rear panel on the control to access it. Calypso Service Manual
Jul 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Mitsubishi 65807 won't power on
hello it's possible the glass fuse may blown inside the tv take the back off and check but make sure the power's off
shaun
Oct 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
There is no power on the unit although it is plugged into a live outlet.
Possibly you have a burned out control board or a burned out control panel. I had a similar problem. I changed the control board first and it ended up being the front control panel.
Nothing worked on the front panel. No lights came on and no beeping sound when you pushed any button. I should have done the front panel matrix test first in the manual. But the manual lead me to believe only one button or one light would fail. For some reason the whole front panel stopped working.
If you problem is the same. Do the matrix test on the front panel. If it checks out okay then it's your control board. I believe if the motor control board is the issue you would still see the front display working.
The fuse is on the motor control board. Do not try checking anything till you view the manual below.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Aug 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Honda Passport 2000 - none of the windows rolling
Sounds to me like you have a bad power window relay. Start by checking the power supply to the relay. Should the relay be bad replace and the window movement should be restored. If this doesn't take care of the problem you may need to replace the master switch in the driver door. The master switch allows all the other switches to do their job. If it malfunctions none of the windows will work. Hope this info helps, good luck!!!
May 11, 2009 | 2000 Honda Passport
Front panel lights up but no buttons work and no sound.
YOU MAY HAVE A BLOWN FUSE IN THE POWER WIRE .......YOU MAY BE JUST GETTING POWER TO THE MEMORY SIDE OF THE RADIO THERE SHOULD 2 FUSE'S CHECK THE POWER FUSE IT MAY BE THAT EASY......GOOD LUCK
Feb 20, 2009 | Car Audio & Video
Calypso washing machine has no power!
This is the worst washing machine ever..the caylso by whirlpool,,, I want in on an lawsuit.../
Aug 10, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso - Will not start
You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
139 people viewed this question
Dan Webster
Dan Webster
Sal De
