Question about Kenmore Washing Machines
Friends washer - she tells me that it will not fill before it goes into the agitator mode almost at ones. The final spin does not get the items ready for the dryer - they are very wet at the end of the cycle. Kenmore 110 22952 100
  • 958 Answers
You may have a problem with your water level switch. because it is the one waiting for the water to rise up before running the agitator.
tnx 4 using fixya,
drcool
Posted on Jul 29, 2008
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Serial # SD117482G
Most likely the control or timer. What is model #?
Nov 17, 2017 | GE WBSE3120B Top Load Washer
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
Washer fills and goes to agitation cylcle, but weak to no agitation. Upon final spin cycle, began making a loud rapid ratcheting sound and did not spin at all. Machine did drain. I did not observe the...
The direct drive coupling between the motor and transmission has stripped out.
It must be replaced.
This video will help in the repair.
http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=player_embedded
Feb 03, 2011 | KitchenAid KAWS750L Top Load Washer
As washer was on final spin cycle it sounded like a belt came....
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Kenmore Washing Machines
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
82 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
