Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
HDMI to DVI cable connection picture problem
I was told that connecting a HDMI cable from my sat. box to the Hatachi TV would improve the HD quality. Sat has a HDMI connection, Hitachi has a DVI V input.
I optained a monster cable with HDMI from sat. to DVI input on Hitachi set.
hooked up okay, but only get picture when s-video cable is connected.
Is there a "switch " with-in the TV menu or Sat. menu that changes the output or input from the SD video to the HDMI cable. Or exactly what am I doing wrong.
Thanks - my email is rhacpa@airmail.net
  • Anonymous Mar 15, 2014
    I have a sony wega tv cant find what channel or input channel to use to find my satellite chanels that i believe are connected by a HDMI cable. Ive tried cable and satellite imputs and can't find the picture. Had it earlier
  • Anonymous Mar 20, 2014
    I get no output at all on either HDMI channel when connecting a laptop
  • 10,594 Answers
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Posted on Jul 29, 2008
WHAT IS THE PURPOSE OF DVI-HDTV CABLE CONNECTIONS AND WHAT TYPE OF PICTURE DO I GET
The DVI cable was the early HDMI cable . all later sets have the HDMI port . when you had it hooked to a DVI source did you select that port with the remote ? if it did not function the port may be damaged . as to picture it should give you a HD quality picture that your cable box is broadcasting .
Dec 23, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Sony xbr lcd screen going all green on occasion
This is an HDMI compatibility problem. Your cable/SAT box is not playing very nicely with the TV. You can try replacing the cable/SAT box with a different model # or switch your connection type from HDMI to Component (5 wire connection). I hope this was helpful, best wishes.
Apr 17, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
HD READY
I have the same TV & I've tried connecting it through "component" & the DVI but neither work & a Virgin media tech says only an HD TV will work 'the boxdoesn't recognise component
Steve
May 05, 2008 | LG RZ32LZ50 32 in. LCD Television
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
1,337 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
