If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
SOURCE: How do i access the water pump on the frigidaire affinity atf6000
There should be to screws at the bottom on each end of the lower front panel. Remove them and the panel will fall down off its upper locating pins and you can then remove the panel. The water pump should be right at the front on the lower right corner. Make sure you unplug the machine first if you are going to be working in there.
SOURCE: how to clean a affinity frigidaire front load
remove the toe kick panel just below the front door and its located right below the drum
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
