Its a door open or door not closed properly error.
That is the only reason. F:16 means the door is not being sensed that it is closed. If the door is deffinately shut then unplug your washer for 60 seconds and see if the control board is just confused. If you plug it back in and still have the same problem then you need to replace your latch assembly because it's not sensing the door correctly.
---------Thank you.
