Question about Panasonic Lumix DMC-FZ7 Digital Camera
It says the lens cap is on and its not
This is a fairly new camera, not the newest made but new to me.
The lens cap is not on and the camera will not let me take pictures. I have no pictures on so I do not know if the other functions work, like playback.
  • prim hathie Aug 11, 2008
    I have the same problem . Alldo i cleaned inside the lens
    Pr
  • tloughrey Aug 13, 2008
    I have the same problem. It instructs me to remove the lens cover and push the right arrow button. The autofocus seems to engage but never focuses and then it repeats the message. I only had the camera ayear when this started. I presume the autofocus is not working and I will have to send iot in for a non-warranty repair. Flat rate charge of about $160. Seems this should be a factory covered repair even if not in the warranty period. It is a defect.
Phathie,
How did you clean inside the lens?
Posted on Aug 14, 2008
I Have PENTAX MX, With lens for this camera. Can i buy a new digital PENTAX, that might fit, these same lens?
One of the great things about Pentax's digital cameras is their lens compatibility: You can use any Pentax lens made since 1975. But the functionality varies from the oldest lenses to the newest. This guide shows what features work with each lens series and what to beware of when buying third-party lenses.
http://www.robertstech.com/compat.htm
Jun 22, 2011 | Cameras
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
When I turn on the camera it says LENS CAP and it wont record the lens cap is not on!!!!!!! What can I do to fix this?????????????
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Dec 11, 2010 | JVC GR-D30U Camcorder
LENS CAP PROBLEM even if lens cap already removed
Sep 17, 2010 | JVC Cybercam GR-D70 Mini DV Digital...
Hi, Own an Olympus 35sp camera. Need to buy a 49mm lens hood for same. Live in Ireland. Any suggested outlets. Many thanks.
I am in the US, But I believe the UK based Jessops camera shops should have a 49mm lens hood to fit it. I would just get a collapsible rubber one. They are fairly cheap and just screw in the filter threads. fold them back when not in use, and you can still mount your lens cap.
You might also try Ebay. Shipping from the UK to you should be minimal, but some asian dealers offer very good bargains in those kinds of goods too.
lightspiritphotography.com
Oct 24, 2009 | Photography
Wide angle cap vs wide angle lens
The cap is a plastic disk, usually black or silver, that snaps on at the end of the lens to keep the lens clean. Some lenses have two caps, one for each end when not attached to the camera.
Some cameras don't use a "loose" cap; those cameras generally retract the lens into the camera body and "close" a door in front of the lens.
Many, if not most, camera users do not use a cap (my guess).
The wide angle lens is generally an "optional" lens that can be used for group or scenery pictures when you want to shoot a "wide" picture. A "normal" lens is generally around 50mm (plus / minus 5mm). A wide lens is anywhere from 17mm to 24mm (or so).
I recommend obtaining a wide lens... with a cap.
Hope this helps!
Sep 10, 2009 | Casio Exilim EX-Z57 Digital Camera
When i turn my camera on i get a lens error 113,0,0,0 what is that and how do i fix it?
The lens/zoom has tendency to stick. Try newest batteries and try several times to turn on and off. If all else fails, Kodak will fix it for $50
Jul 02, 2009 | Kodak Easyshare M753 Digital Camera
How do I attach lens cap string?!!!
go here and download the manual in your language
http://uk.leica-camera.com/photography/compact_cameras/d-lux_4/download-147_2.html
it's on page 9-10
Robert
Please take a moment to rate this solution
Jan 23, 2009 | Cameras
Lens problem
That's a fairly new camera, and is likely still under warranty. Contact Canon first to see if they'll help 1-800-828-4040 or 1-800-OK-CANON (1-800-652-2666).
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or Canon will not help, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 06, 2008 | Canon PowerShot SX100 IS Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
