LG WF-T652A Slow water fill
Machine takes forever to fill with water. The cold water just dribbles in. All taps are on full and connected well, ater pressure in the area is excellent.
  • Anonymous Aug 27, 2008
    cold water dribbles in. takes over one hour to fill. plenty of water pressure into house. all new plumbing fixtures.
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Posted on Jan 17, 2010
LG Top loader WF-T7016PP Won't take in cold water? Help please
turn tap on at the wall
check that the water in solenoid is operational
check that the stop washer in the tap is allowing water in to the machine
check that the water level is set correctly
call a technician does water flow if hot water is selected
Jul 10, 2016 | LG Washing Machines
I have a LG Punch WF-C5856TC washing machine. Off late, Notice that the water is trickling in rather than flowing. Hence it takes really really long time to wash clothes. Pls advise
The first place to look is the inlet tap in the wall
even you have the tap on full the tap washer inside jams and prevents the full flow of the water
next check out the filter in the hose at the tap or at the washing machine end
next replace the water inlet solenoid
you can check this by changing the hose from the hot water tap onto the cold water tap and pressing the hot water button to fill
solenoids do not know the difference , they just work when the power is applied
Sep 08, 2015 | LG Washing Machines
Lg wf 801 won't fill
Yes , It can be related to the control board, but first of all please make sure that there is good water flows in both the inlets, check the flow after the valve , ensure that the inlet filters are not clogged and check all the connections from the harness to the valve and panel
Jan 19, 2013 | LG WM Washing Machines
I have a LG WF-T753A washing machine. The hot water is not working, but has in the past - cold water is fine. When it goes to fill up with Hot only, a slight hum, and then it stops, but no water. Have...
Check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
May 04, 2011 | LG WFT1071TP Top Load Washer
Problem: the cold water just dribbles out when filling the tank and it takes forever to fill the tub.no problem with the hot water flow.
If you have water pressure to the cold inlet valve and the valve's filter is clear, you probably have a failed inlet valve...Replacing the cold valve should fix the problem..Not a big or expensive job..Good luck....Nomess
May 20, 2010 | Washing Machines
Problem with the flow rate to the entrance valves
Turn the water valves off and then unhook the water supply hoses from the machine. Look into the hole the hoses were connected to. Use a pliers to grab the tab on the filter screen(s) and pull them out of the water fill valve(s). Clean, reinstall, and reconnect hoses and turn valves back on. Most often you will find that the cold water supply is the culprit.
Feb 02, 2009 | LG WFT1071TP Top Load Washer
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
I have an LG washing machine model WF-T755A After washing completed, if water not turned off at taps, the unit slowly fills up with water. The last time causing it to overflow and flood the floor
Water inlet valve is not sealing off 100%. Replace inlet valve (the part where the hose attached to the machine). didn't find that exact model listed so couldn't give you a part number. Usually LG's have a separate valve for the cold and the hot. If you turn off one valve where hoses connect to household plumbing you should be able to figure out if it is the hot or cold. (most often it is the cold) Leave both valves off when not using washer until fixed. (note: usually on LG washers, if you have unit connected to power and the door closed, if it fills with water as your machine did, the water level switch will trip and automatically pump the water out, even if washer is not in use and the power is "off".)
Aug 31, 2008 | LG Washing Machines
Hot water in washer comes out fine. Cold water is very slow coming out. It dribbles and takes forever to fill.
Clean inlet screen where hose attaches to machine. Water from water heater is generally "cleaner" as sediments have had a chance to settle out in the water heater. Cold water carries more stuff directly to the valve screen. Check also for kinked hose.
Aug 28, 2008 | Washing Machines
Washing Machines Logo
177 people viewed this question
Top Washing Machines Experts
