Question about GE Dryers
Will not heat
Flame will not come on it will tumble on all cycles but will turn on flame
  • 525 Answers
Your Issue is;
"Flame will not come on it will tumble on all cycles but will turn on flame"
Based on the information provided above, I am unable to access my database to provide you with exacting information. A valid model number was not provided. However, I have provided some common solutions to help guide you in your search.
This information is for a gas, generic model dryer only!
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
This link shows an exploded view for disassembly procedures.
http://www.repairclinic.com/0100_19.asp
My Solution is:
Temperature Switch;
Make sure a positive heat selection has been made, still no heat, then check these:
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Hope this helps!
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 29, 2008
No heat from tumble dryer
Hi.
If dryer is electric check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, element and fan.
If dryer is gas check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, igniter, coils, burner, flame sensor and fan.
Dec 14, 2011 | Washing Machines
Heats but wont stay heated
If the flame come on to start with, but then goes out and won't come back on I would suspect you have a bad coil on the gas valve.
If you see the flame cycle on and off, but the flame does come back on again this is normal. The flame needs to cycle on and off and not be on steady or the dryer would get to hot.
If the flame is cycling ok and the cloths just don't get dry then you need to check your dryer and vent for lint build up.
Aug 02, 2011 | Roper RGX4634KQ Gas Dryer
Furnace motor turns on, igniter lights gas and as soon as the blower turns on the gas shuts off. It will cycle like this for 2-3 times then seems to operate normally.
Sounds like the unit is triping the limit before the blower comes on. Try puting the fan ON at the thermostat and see how the burners react with a heating call. If they stay on then I would look at the wiring diagram and try and determine what turns the blower on it the heat cycle. is it temperature or time delay through a control board. Hope this helps.
Jan 21, 2011 | Heating & Cooling
Hi, Two problems. The first I believe is rollers - drum clunks when turning. The second problem is it blows cold - no heat. What part is needed to repair this. Thanks.
Well, check the rollers for flat spots, could also be the belt drive pulleys especially if you've overloaded the dryer and caused it to stop tumbling.
Secondly while the front cover is off look at the heating element used to trigger the gas valve ( igniter ) next check out the light or flame sensor, if the pilot flame ignites but the major flame doesn't then the sensor may be malfunctioning.
Jun 14, 2010 | Amana NDG2335AW Gas Dryer
Model SDG305DAWW, gas unit...begins to dry and then stops...timer stops and unit continues to tumble but no heat...turn unit off and wait for about 2 hours then can dry again....replaced cycle timer,...
Sounds like you have the same problem I did. You need to replace the flame sensor. Takes about 15 - 30 minutes. You can order the part online here
Feb 06, 2010 | Maytag Dryers
Dryer is tumbling properly,but not drying. there is absolutely no heat.
pop the cap on the front of the dryer an turn it on
if you see the igniter glow an the flame comes on wait an see if the flame stays on if it it shuts off like 10 sencds later,you have a block vent
if no glow or flame u got a bad thermal fuse
if it glows ,flame an shuts off like and then comes an goes u have bad coils...
good luck post some feed back thanks
Feb 01, 2010 | Kenmore Dryers
Kenmore gas stove not coming out of pre- heat model 66575842001
This sounds like a flame sensor problem. No signal from sensor will shut down gas valve. Check flame sensor position in flame/or replace
Sep 02, 2009 | Kitchen Ranges
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Dryers Logo
96 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
