Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Frigidaire Dishwasher How do I remove the blue protective material from the front of my new dishwasher?
    Habit-Forming:
  • 35 Answers
It should just peal off from the edge like a piece of tape.
Posted on Jul 30, 2008
How do i remove front door cover?
Good Morning Friend,
I understand you are replacing the soap dispenser in your Frigidaire dishwasher, model# FDB1050REC, and want to know how to access the screws to remove front panel of the door. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals for this repair. I suggest contacting your local authorized technician for further assistance. I hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher not coming on
We had a similar problem,,,, if you reset the circuit breaker,,, may work, but if not, the dishwasher has a power/control board behind the front cover (6 large round screws) pull front cover off with handle and find smaller square cover,,under that is a board WITH POWER OFF remove board and look on back for a part that is discolored darker than rest of board,, you may or may not see it, this looks like a resister but believe it is a fuse,,, need to order new board from wherever,,, got mine from sears 160.00 worked and was cheaper than someone coming out to do the same thing for more money or buying a new dishwasher. good luck
Mar 15, 2014 | Frigidaire FFBD2409LS Builtin Dishwasher
Frigidaire dishwasher not working
We had a similar problem,,,, if you reset the circuit breaker,,, may work, but if not, the dishwasher has a power/control board behind the front cover (6 large round screws) pull front cover off with handle and find smaller square cover,,under that is a board WITH POWER OFF remove board and look on back for a part that is discolored darker than rest of board,, you may or may not see it, this looks like a resister but believe it is a fuse,,, need to order new board from wherever,,, got mine from sears 160.00 worked and was cheaper than someone coming out to do the same thing for more money or buying a new dishwasher. good luck hope it works
Mar 11, 2014 | Frigidaire Gallery FGBD2435NB Full Console...
Can you please tell me where i can find a manual for dishwasher tisira l65x. we have just had it installed by landlord and it is not letting water through. we have checked the plumbing and it is fine but...
Hi and weclome to FixYa, I am Kelly.
This is a new unit..... Look inside the bottom tub area for a domed plastic float and remove the packing tape from it. (usually either front left or front center. Also if there is a flood switch with packing material on it..... it usually will be mid point RH side of the lower tub area.
I searched for a manual without success. This appears to be a contractor only dishwasher.
I am certain the problem your having is that not all of the packing materials have been removed. The tape is usually on the inside of the tub but... depending upon manufaturer there can also be tape under the unit. Look for paking tape and remove it. The tape is usually white or a light tan.
The water level sensors are taped during shipment to prevent damage.
Thanks for choosing FixYa,
Kelly
Apr 11, 2011 | Dishwashers
1st hookup
Hi and Welcome to FixYa. I am Kelly.
To the best of my knowledge and with well over 35 years experience I have yet to have to prime a dishwasher.
If this is your very first hook up and your certain that the water supply to the unit is on check to make sure all of the packing materials have been removed from the unit. Especially check in the area of the water level sensor. If the packing material is holding the float sensor up or.... there is packing tape over an electronic sensor it will not fill. After you have made sure all packing materials (see installation manual that came with the Dishwasher) have been removed and it still does not work then call for in home warranty service.
Thanks for using FixYa,
Kelly
Apr 29, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Almost new dishwasher. Lights come on but pump doesn't start
You have some debris in the little pump that pumps the water out of the dishwasher. To get at the pump you will remove the lower front panel and follow the drain line down toward the floor. there u will see that the drain line is connected to a small pump. disconnect the drain line and remvove the two screws that hold the pump to the frame. look in the pump and you will see your problem debris [often a chunk of glass or bone] Remove it and put everything back to gether and you will be back in business.
Apr 07, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher Leak
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Feb 27, 2009 | Frigidaire 24 in. PLD2850 Built-in...
My Frigidaire Dishwasher FDB510LCB0 the water won't stop running in. I have to turn the valve off after each load of dishes I do. What could it be and where is it located on the dishwasher.
thats the water valve .its under the dishwasher .its blue ,whtie or yellow .has two wires to it and your house water supply connects to it and rubber hose going up to dishwasher.you can do it God bless ,tom
Jan 03, 2009 | Frigidaire Dishwashers
Steam eating my cabinet top up
You can buy a metal strip with a small angled edge to fit under the worktop above the dishwasher. I have one of these and it has protected the worktop for 10 years,
Dec 22, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Electrolux
Electrolux
Mike Cairns
Mike Cairns
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
