Question about Cobra 200 GTL DX 4-Channels Base CB Radio
No output I have a Cobra 200gtl. It has no output at all. When I key it up the transmit light works but the radio meter just falls. It shows nothing on my external meter and does not even draw on my power supply which I can tell because it has an amp meter on it. I kind of think something burnt out that kicks in the transmit side because of the no current draw part. Any help would be greatly appreciated. Thanks
  • 3 more comments
  • richt1969 Aug 28, 2008
    me too -it has been working fine for 3 months and then it has been inactive for a month. Just turned on and I have the same problem that you describe. Did you manage to resolve it?
    Richard
    richt1969@mailshack.com
  • Anonymous Aug 29, 2008
    Same problem with mine! First low TX power, now no transmit in all modes, but TX LED ist lighting...
  • Anonymous Sep 03, 2008
    no power when i key the mic .power meter just falls.on ssb the same
  • kaden1060 Sep 10, 2008
    I HAVE A COBRA 200 . THE RADIO WAS WORKING GREAT NOW WHEN I KEY THE MIC THE NEEDLE JUST FALLS ITS AS IF THE OUT POUT HAS GONE . BUT WHEN ON SSB WHEN I WHISTLE INTO MIC THE NEEDLE MOVES SLIGHTLY . CAN ENEY ONE HELP.
  • Anonymous Sep 16, 2008
    It was the driver transistor RD16HHF1. Write an email to cobra. They send a new one. Sort it out, then sell the radio quickly! 73,s 13EL121
Take the cover off the top back right corner where the speaker plugs in look for a transitter burn out
Posted on Sep 29, 2008
Thanks for all your response. In the end my went back to a shop inthe UK (Knights) and they did fix it. It was the output transistor (or the middle stage he said) and it cost less that £20 to fix.
Thanks again
Rich
Posted on Sep 18, 2008
Posted on Sep 16, 2008
The problems with the 200gtl was a ongoing problem with final driver I also bought mine 2nd hand and it lasted 31 days
then the samething you described took it to a local tech and had it repaired at a price of $110 But now it works very well and I really like this radio
Posted on Aug 31, 2008
No its the same in all modes. Its RX is OK and the TX light comes on but with no output. If you key the mike and then change bands the needle jumps a little and then slowly falls. Very odd!!! I have taken it to the shop today but they have said they do not have much hope they can fix it as it is a know fault that has to go back to COBRA. I bought mine second hand so that isnt an option :o(
Same problem with mine. First minutes low TX power, then nothing, but TX LED is lighting in all modes...
Posted on Aug 29, 2008
See if it talks on fm
Posted on Aug 14, 2008
THEY ARE JUNK RADIOS STAY AWAY EASY FIX
Posted on Nov 15, 2008
My cobra 200gtl rev 2 cuts out on ssb after a few minutes
It sounds like the final transistor may be shorted/burned out. If you don't know how to locate or test the transistor you'll have to take it in to a tech. These transistors are usually quite cheap but as to the labour cost it depends on your tech. Usually what causes this damage is a bad antennae match or a bad antennae itself, even a shorted antennae cable. After you've repaired the radio check the antennae and cable first before connecting it up again, then check your match with an SWR meter. Good luck
Mar 23, 2014 | Cobra 200 GTL DX 4-Channels Base CB Radio
Meter don't work
Hook radio to a dummy load with a watt meter in line---if no actual power being transmitted radio will not go to cal or show transmit power.
May 19, 2012 | Cobra 29 LTD CB Radio
My Cobra 29 LX receives including the weather but can't transmit
If the relay contacts are closing. You may have blown the output transistor, however a broken wire in the microphone can also create the symptoms you describe. .
you can check by using a #47 light bulb soldered to a PL259 connector as a dummy load. If it lights, the carrier is present, but you may not have voice modulation which will show as differences in light intensity as you speak. If no modulation, the microphone is the first thing to look at.
The relay contacts may also be very pitted or corroded and not achieving continuity.
Feb 17, 2012 | Cobra 29 LTD CB Radio
My cobra 200gtl has no transmit
hi More than likely your pa transistor has blown have you checked it with a power meter if so r you getting the red tx led when the ptt is pressed if so then your problem lies with the rf transistor
replacing rf transistor
Jan 18, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 18 wx st receives-wont transmit
Take the cover off, flip it over solder side up, check all solder joints for cracks, cold solder joints, check the safety diode where it comes in the radio, before I go further, can you pick up the weather channel?...Does the PA work?...need to check the pre-driver and finals,audio chip, hook up the power meter using a coax three foot jumper from the output from radio to the input of the watt meter, then the antenna, first check the SWR, on the scale on the meter to cal/swr mode,adjust it to spec, then while still keyed down turn the dial to SWR,if it is the safe range your ok,then turn the Dial to 10 or 20 watt scale and key the mic. Does it have any wattage? If not suspect the finals, they are located on the back rail, if it does have RF then its the audio chip, its located on the right side rail facing you,closest to you.remove it and replace it with same ....hope this helps....
May 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 29 chrome
you could have a bad soilder but probably your voltage regulator went out.
Dec 15, 2009 | Cobra 29 LTD CB Radio
Cobra 29LTD CHROME low tx no mod, rx good low Vol, talkback good
1 why would you change the finals?? Have you checked you antenna? How are your SWR's? Crappy antenna's cause a lot of problems.
Use an external meter to see what the SWR is, and see what the output is PEP. If its low, then there is something wrong. If it is High, change the mic and turn up the dynamic all the way.
Next. Have you been messing around in there?? Tryin to get more wattage? You turned VR4? If you thought you were turning it up by turning it all the way to the right, you turned it all the way down. Turn it all the way to the left.
Jun 05, 2009 | Cobra 29 LTD CB Radio
Cobra 29 wx st
IF YOU CAN RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Feb 14, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 200gtl High Power Transmit problem??
Depending on the type of power supply, radio frequency (RF) energy from the transmitter may be 'fooling" it into thinking that you're overloading it. Check to see if there's any discernible dimming of the meter lamp when this problem occurs, if so, the supply is the culprit.
Otherwise, its probable that the final amplifier transistors are overheating, either they are 'leaky' or not properly attached to the heat sink.
Jun 23, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
434 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
