Question about E-Machines eMachines Desktop PC
Lan connection I have a local lan connection problem and the ethernet cannot connect to allow me on line
    Scholar:
  • 160 Answers
Re-Install the NIC Card Drivers
Enter the TCP/IP address
click on Ok
Restart the system
Posted on Jul 29, 2008
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
What is difference between lan card and modem
The difference between a Lsn Card and a modem are this - A Lan card is a card that you slide into the side of a laptop and it can allow you the ability to get onto a network wirelessly. A Lan card for a PC allows a Lan connection by way of a CAT 5 cable that will allow you to get onto the internet or if a crossover cable is attached to your pc to another you are directly connected to the network. A modem is a piece of hardware that is installed into a slot in the PC that will allow you the ability to get onto the internet by attaching a phone line to it through the RJ 11 jack (which it comes with 2 rj11 jacks on it).
Here is the picture of LAN port and Modem port
Dec 24, 2010 | Siemens Computers & Internet
How to hook it up to computer
alright man routers are easy look you need to have a MODEM!! INternet MODEM.. that has a LAN LINE or cord
1. connect your modem LAN line to the router, the router MUST have a HUB where you can plug it in the router hub it should say LAN connect it there!!
2. connect the ethernet cable that came with your router ,connect the ethernet cable to the router on the hub that says 1 connect it and the other side connect it to your computer!!.
3. now insert your disc that came with your router!
adjust your router settings!! allow wi-fi if available and put your password!!
4. your router is set!!
thank you i hope this helped you!! leave a testimonial!!
Aug 02, 2010 | NetGear WGT624 Wireless Router
Ps3 was fine on line this morning but tonight in will not go on line and says error 80130182 i am using a ethernet cable to try and connect can you help ?
Hello, this error means you basically can't get connected to Internet. It's due probably to an IP conflict on your local LAN. Try to do the following: - switch your PS3 off - switch any device connected to your local LAN (laptops, desktops, iphones, etc..) - unplug power cable from your modem/router - unplug ethernet cable from both PS3 and modem/router - wait 1 minute, plug everything right back - switch your PS3 on and see if this error has gone.
Good luck, Peter_Rei
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
I've got an Everex 3400+ and when I plug my cable in from my cable modem into the internal modem it's not showing that it's connected. Is there a driver I need to download. can you recommend a network...
Please dont connect a cable modem to an internal modem.
These are not the same types of device.
you need to connect from the cable modem to the ETHERNET port.
They look similar but ethernet is slightly larger.
Dont use a telephone cord for the ethernet connection it is the wrong one.
Sep 14, 2009 | Everex GA3400 Refurbished AMD Desktop...
Ethernet card
hi there. The ethernet card is an interface that allows your computer to be connected to a LAN (Local area network) and to a Cable/Dsl modem to be on the internet. The connector looks bigger than the one of a regular telephone jack (it's actually double). If you don't have the ethernet card you can't go on the internet or on a LAN.
From the back of the modem or router you should connect a cable to your ethernet card of yor computer. Only after you did that you can try to connect to the internet.
Let me know, or be more specific.
thanks
Mar 30, 2009 | Dell Computers & Internet
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Jan 19, 2009 | Dell Ethernet Card Network Adapter
ActionTech Wireless Gateway can't route Wireless to LAN
Disable firewall on all devices. All types of security sofwares should also be disabled in order to ping each devices.
Oct 07, 2007 | Actiontec GT704WG Wireless Router...
E-Machines eMachines Desktop PC Logo
23 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
