Question about Whirlpool AWM8103/1 Front Load Washer
Fp fault my washer goes then stops showing a fp fault i switch it off at the mains then restart it and it goes for a while then throws the fp on
  • bindybids Sep 19, 2008
    Our washer is a AWM 8062 - 6K FP fault comes on the display, but my instructions are in Spanish as its in Majorca,any suggestions as to what the problem might be and how to fix it. Pump has been checked and wondered ifs because we use the short programme all the time it is worn out. Put it on a spin and its fine.
  • pammay Feb 06, 2009
    I have this too. I have changed the filter as it was broken but still the same problem. Any suggestions?
I have the same fault on the whirlpool AWM8163/3 it indicates a drainage problem so check the filter and pump housing and all the pipes for blockage, even the drain pipe, i have done all that but the problem still exists, I'm gunna have another crack at it now and i'll let you know how i get on
Posted on Sep 09, 2008
2 Suggested Answers
SOURCE: fp fault
The problem is pump is either broke or there maybe something is caught up in the impellor, easy to fix, remove front cover undo spring for door seal unplug electrics, remove both hoses on pump and undo bracket, then check pump, had same problem myself it was an elastic band and coins got it fixed myself saved a fortune hope this helps.
Posted on Dec 29, 2008
My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Error code 26
You have a clog some where
F26
Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
Front Load Washer Repair Not Draining or Spinning How to Unclog the Drain...
May 31, 2012 | Maytag Washing Machines
Machine will not spin and displays FP fault
Hi There
I have this for you and i hope this will get you in the right direction. Let me know how this goes. By the way Merry X-Mass and a Happy New Year.
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FP fault 43
code 43 is an out of balance switch problem.Once replaced, would fix the issue.
One trick that might work ;-
I unscrewed top cover, then unscrewed and lifted up the grey computer cover. The balance switch is underneath on the right with a yellow and white wire coming off.
I removed switch from clip and then removed the wires/clips from contacts. There was definitely corrosion on the contacts. I soaked switch overnight in vinegar. Then rinsed with water. Then dried switch out for day.
Put it all back together and am now on second load of washing.
Thanks.
Jul 01, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fp fault
Dec 14, 2008 | Washing Machines
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirpool washing machine
The FP code just means that your filter is clogged or has a hair doo-dad or something in it that needs to come out. There are Guys on YouTube that will show you how to do that, step by step, just google Whirlpool AWM8103/1 fault codes to see them. Tip* Have a Large but Shallow pan or container of some sort ready to catch the water that the filter will be holding in it's line because it will come rushing out when you open the filter housing! Towels will be useful. Merry Christmas!
Dec 03, 2017 | Whirlpool AWM8103/1 Front Load Washer
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Whirlpool AWM8103/1 Front Load Washer Logo
667 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
