Serial error in dosbox after getting Opening message: "errors occured framing 1, parity 0, overrun 0 (if0:0), break 1"
alocenar
  • 293 Answers
SOURCE: 0*0eedfade error
what pc configuration you have?
maybe the game software is not compatible to your pc
Posted on Aug 06, 2008
SOURCE: m3plugin.dll
please tell us how to resore requird dll for error
C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
Posted on Sep 21, 2008
pankaj_dic
  • 1250 Answers
SOURCE: During installation at 4% error
have you change the RAM
Posted on Oct 28, 2008
ITTech7574
  • 85 Answers
SOURCE: my zwinky has an error
Try removing cookies of your curent internet browser.
Posted on Aug 31, 2009
SOURCE: I am getting an Error 1806: PCT/PnP Error!
u have to select proper restore point that generated before ur problem was begun.... i hope it will solve ur error
Posted on Nov 28, 2009
What is the meaning of the error "invalid axes"?
This is problem with graphing differential equation. Invalid Axes error occurs if Axes=TIME or if t(time) is set as a CUSTOM axis. This is important to noticed: if Fields=DIRFLD you cannot plot a time axis. See captured image:
This graph represented differential system of equations y1'(x)=y2(x), y2'(x)=-y1(x) for initial conditions y1(0)=0, y2(0)=-1.Finally, x axes=y1(x) and y axes=y2(x)
Feb 08, 2012 | Texas Instruments TI-89 Calculator
My wifi will not use my wifi router after upgrading ubuntu to ver 11.10 it worked before and i can use different wifi routers lspci 00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge 00:01.0 PCI...
first make sure your wireless adapter is not disabled you can check it by running rfkill list in terminal if it is type sudo rfkill unblock wifi [second you can try activating and deactivating by typing sudo ifdown wlan0 and sudo ifup wlan0 me personly have kept to 10.10 the 11.04 seem to have a few glitches you can also check for additional drivers
Nov 27, 2011 | Canonical Ltd. Ubuntu
Computer does not start . When powered up it give message on monitor screen " Parity errorsystem halted" . Please suggest the solution for it?
@mahesh_0552
Parity Errors are caused by faulty RAM or memory chip. This occurs when data is leaked when it's passed thru the RAM (usually during POST - Power On Self Test - this is the mode when the computer boots up and initially check for hardware components connected to the computer). In this case, you need to replace your memory.
More info at http://support.microsoft.com/kb/101272.
Sep 06, 2011 | Computers & Internet
I had an alarm on 9390 which read : "Battery Test Fail". What would possibly cause it and how would I best prevent it from reoccuring.
This error indicates that the battery packs are no longer able to supply the expected run time or load capacity that the UPS needs. The batteries will need to be replaced.
May 11, 2011 | Powerware 9390 UPS System
Tally mt661 printer gives data overrun error after printing a page or two, how do i solve the problem?
The Data Overrun error is normaly associated with the incorrect serial interface settings on the pritner or the serial cable may have the wrong pin configuration or be damaged in someway.
I would recomend checking the serail interface settings including the follwoing settings; Parity, Protocol, start bits and stop bits
Feb 09, 2010 | Tally MT661 Printer
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
1 Adaptec RAID 3085 cause parity error in server while 2nd don't!
I'm thinking you should be checking the drives. If one of them is failing, you will get parity errors.
Picking apart parity problems TechRepublic
Mar 04, 2017 | Acer Altos G530 Server
Parity error issue with TF85 DSSI based on VAX4000 - 700
If cleaning the heads using the cleaning tape did not help, then there are 3 possibilities that I know of:
1) The heads are sufficiently dirty to require direct cleaning with a more powerful solution.
2) The heads are defective.
3) The heads are out of alignment.
Parity errors are not usually controller problems. If the head alignment has drifted enough, you may be missing a track when recording. An initialization includes writing format information at the beginning of the tape. This is "re-read" during the process to confirm correct writing. This is the part that is failing.
Keep me posted.
Dan
Feb 20, 2009 | Compaq DLT Tape Drive (TF85) DLT Tape...
Rtl 8139D drivers for Red Hat 5 enterprise edition
I have no choice and open terminal then type “init 0′ (shutdown) :D. Then switch back to Windows XP to find the type of driver I need to install on Linux RHEL 5 and find solution over the internet. Noticed that I am using Realtek RTL8139/810x for NIC on Windows. After that, quickly go to the internet to find “how to install Realtek RTL8139/810x on Linux RHEL 5“. Then, I found that many crappy thing and **** suggestion over the forum. I read almost all Linux forum and follow all the sugesstion included to use ndiswrapper to install that Realtek NIC driver. But it doesn’t work on my machine. Yes I confess that I am new in this matter and perhaps ndiswrapper is too advanced for me.
Then, I have decided to try and error. I go to Realtek official website to see if I can get the specific driver for Linux. Found that:
RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L)
RTL8139C(L)+/RTL8139D(L)/RTL8100(L)
RTL8130/RTL8139B(L)
all at the same download page. Then I made I my own conclusion that, Realtek8100 or Realtek8101 can be use as well since I can’t find any RTL8139 driver for linux over the internet. Too not wasting your time to read my crappy story, then download this driver over HERE. DOWNLOAD DRIVER HERE, before that make sure you login as root. After download complete, just write the following command on your terminal:
[root@localhost ~]# cd Desktop (i put the file on Desktop)
[root@localhost Desktop]# tar xvvf r8101-1.001.00.tar.bz2
[root@localhost Desktop]# cd r8101-1.001.00
[root@localhost r8101-1.001.00]# make clean modules
[root@localhost r8101-1.001.00]# make install
[root@localhost r8101-1.001.00]# depmod -a
[root@localhost r8101-1.001.00]# insmod ./src/r8101.ko
[root@localhost r8101-1.001.00]# lsmod | grep r8101
r8101 28688 0 <—if this appear, then you’ve installed the driver successfully:)
Then check if your ip have configured correctly or not
[root@localhost r8101-1.001.00]# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:1C:25:4D:9A:0A
XXXXX XXXX MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:177 Base address:0×2000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1611 errors:0 dropped:0 overruns:0 frame:0
TX packets:1611 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:4526976 (4.3 MiB) TX bytes:4526976 (4.3 MiB)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
Since you can see the ethX which X is 0,1,2,3 (mine is eth0)…. instead of just lo and sit0, then its working now. NIC driver has been installed successfully.
Finally, on your terminal type:
[root@localhost ~]# system-config-network
You can see on hardware tab there are Realtek Semiconductor with status ok. Then, move to Devices tab, and click New > Ethernet connection > Forward > Choose REaltek Semiconductor…. > Forward > then up to you whether want to set DHCP or set static IP.
Now you can open Firefox or Konqueror and start browsing internet happily:)
[p/s] If check again on your terminal with ifconfig -a it should return your local ip address under the eth0 which is 192.168.1.* ; * is 2-255
May 16, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Computers & Internet Logo
732 people viewed this question
David Payne
David Payne
