Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
At first water was leaking out just from the soap dispenser but now water gushes out from the door when the machine starts its spin cycle. I'm not sure what the problem is. THe seal seems ok - please help. Is there a different procedure to unblock my Washer Dryer or is it the same? I have exactly the same problem but a different Washer model. Thanks
My hubby followed the advice on here about the filter when the drawer was spilling water at the end of the wash cycle.... perfect now back to full working order and the stuff he found in there was disgusting.
Posted on Feb 18, 2013
  • 24 Answers
In this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Posted on Apr 18, 2009
2 Suggested Answers
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Posted on Mar 07, 2008
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Water leaking from detergent drawer Hotpoint WMD 962
what is your model number is then we can get started then okay
Feb 04, 2013 | Hotpoint Washing Machines
Frequent leaks through soap drawer during rinse cycle
Possible that the dispenser drawer is out of alignment or is the suspect. You can remove and check the mountings
click on : Dispenser
Jan 24, 2013 | Tecnik TKL9260 Front Load Washer
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
When machine spins after wash water gushes out of detergent drawer. Checked black hose from drum and found a blockage of colour catcher sheet thought this was the problem but water is still gushing out the...
Hi.
The problem can be a defective pressure switch. The pressure switch detects water level. Pressure switch not working correctly may result in overfill. Try cleaning the rubber hose connected to the pressure switch. Check also pressure from inlet hose and look for blockage in detergent drawer.
Aug 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD71 washer/dryer
Hello farijl,
Welcome to Fixya,
You said, Water gushing from powder dispenser drawer. I have been told to take out drawer and put to one side. Looking into drawer space at back on right hand side there is a hole to be unlocked. It is so scaled up I cannot see hole. Can you help me or do you have an illustration fo what I am supposed to be looking at and unblocking ? Hope you can help soon. Floor is flooding every wash and cannot afford to get man out.
I found what you are looking for!
Below I will post the site for your WD71 User guide.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/531INST_016437770-02_WD71.pdf
If you scroll down to page 5 it will show you what and how to remove the transit brackets.
the dispenser drawer info is on pages 19 and 20.
My first post was incorrect about the bolt.
The American washers us a bolt!
Sorry.
You should be fine now and able to remedy this by your self
Let me know if you have any other questions.
Huuum
Please remember to leave a rating
Thank You
The detergent dispenser
will not close properly or is
collecting water?
1. Check the drawer is properly aligned.
2. Clean the dispenser drawer (see Care and Maintenance).
Oct 17, 2008 | Hotpoint Ultima WD72 Front Load...
Water gush in power drawer
You have a seal that is not working right for one. and 2 you have a water pump that is not working. because it is not limiting the water supply.
Aug 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Mar 06, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
395 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
