Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
LCD screen not working
I just bought this machine since the first time i plugged it in the screen has been blank. I have installed the ink, plugged in the USB, registered it online and nothing....
Every button I push makes an error noise.
Should I return it?
  • turtle1010 Sep 28, 2008
    I have been using my MFC 240 Brother for 8 months. Now, all of a suddent the LCD screen has stopped working! It is always completely blank. It prints, scans..etc...everything normal, but without an LCD screen I can't send Faxes or do other functions! Problem is, I have lost the receipt and I can't return it to the store I bought it from for repair/replacement. Can any one assist me on why it is not working??
  • 48 Answers
Posted on Aug 21, 2008
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
XPS Gen2 / M170 display issue, mind boggling
What are the BIOS versions and what are the mother board revision numbers?
Mar 10, 2014 | Dell XPS M170 Notebook
My brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
Jul 13, 2012 | Brother Sewing Machines
Have just bought Brother printer and from the moment I plugged in the Lcd was blank and the exclamation mark has not stopped blinking. Tried things to no avail.
check the following things
1.check catridges are placed properly and are having ink and safety seal is broken2.install printer driver in your pc(after installing the driver only you have to connect your printer to your pc)
check this link also
http://www.brother.in/brother/category/printers/26.aspx
Jan 28, 2011 | Brother Office Equipment & Supplies
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Bought brand new ink but it keeps saying it doesnt recognise the ink i have put in
Take the cartridges out. Clean the contacts on the cartridges, (brass color,) with a lint-free cloth. With a almost dry damp cloth, wipe the exit areas where the ink comes out, just a couple times. Unplug the machine. Plug it back in. Open the barn door, and install ink cartridges. Allow the ink cartridges to re-align. Printer should work fine.
Nov 16, 2010 | Epson Stylus Photo R320 InkJet Printer
My printer says it is offline
To solve the problem, please see the following:
  • If the printer status is Offline:
    Check that the printer is online using the following steps:
    VERIFY THE BROTHER MACHINE IS POWERD ON AND THERE ARE NO ERRORS
    1. If the LCD screen is blank, then the Brother machine is not powerd on the machine to see if it wakes from sleep mode. If it does not, then verify that it is plugged into a working outlet and any power switches are turned to the ON position.
    2. Check the LCD screen for any error messages. An example would be "Paper Jam" or Ink/Toner Empty". If the LCD screen shows an error troubleshoot to clear the isssue indicated.
    CHECK THE PRINTER STATUS
    NOTE : These steps or screens may differ depending on the operating system.
    1. For Windows® XP Users:
      Click Start => Printers and Faxes
      For Windows Vista® Users:
      Click Start => Control Panel => Hardware and Sound => Printers
      For Windows® 7 Users:
      Click Start => Devices and Printers
    2. For Windows® XP and Windows Vista® Users:
      Right click on the icon for your Brother machine and choose Use Printer Online.
      Double click on the icon for your Brother machine => See what's printing => Printer => Use Printer Offline (Take the checkmark off.)
Oct 26, 2010 | Brother MFC255CW All-in-One InkJet Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Re install ink
I know this is a dumb question but did you remove the tape off he bottom of the ink cartridge? Also sometimes if you are using a generic ink cartridge the machine may not recognize it. Make sure the cartridge is seated in properly and that it is in the correct location. (not color spot). Hope this helps. John
Sep 07, 2007 | Brother IntelliFAX 1940CN Plain Paper...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
167 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
