Question about NCR 7875
Error 5 for ncr 7875 scale scanner
I get error 5 in scale i read your help bt still not able to understand i remove plastic part on right side nothing work also my scanner only 2 times after that my scanner doesnot scan help plz
  • 3 Answers
If the scanner read only two times is a problem with the communication protocol.
What protocol do you use?
Explain more about your problem with your calibration pricedure
Posted on Oct 08, 2008
  • 3 Answers
The error five appears in the display when the scale loss the calibration you most clibrate the scale this have a button in the front under the metal plate and you need put 0.00 kg and prees the scale zero button wait 10 seconds aprox and put 2.5Kg and prees the scale zero button the scale need 5.00 kg and again prees the button 10.00 kg and press the button at last put 0.00Kg .
Your scale most be ok,The scanner only read two times because no transmit the data to the host or can be programing the comunication.
Posted on Dec 05, 2008
I need USB drivers to allow communication between a pc running Windows XP and an NCR 7875-1000 flatbed scanner/scale. Please copy me at my work email address of james.clark@csi-posdata.com.
First I'd like to thank you for selecting my services. I've located the software for your NRC Scanner scale 7875. You can obtain firmware and related tools from http://www5.ncr.com/support/support_drivers_patches.asp?Class=retail_RealScan
As for the windows drivers they are available for you here http://www.digi.com/support/productdetl.jsp?pid=2628&osvid=57&tp=1&s=0&tp2=0
Select windows xp from the drop down list and then the 4002537_h is the one your looking for, version 5.3
I'll send a copy to your email address.
Let me know if you need further assistance.
Thanks,
Ekse (Niko Ohtonen)
Oct 07, 2011 | NCR 7875
MANUAL CALIBRATION SCALE SCANNER NCR 7875
codigos de barra para configurar scaner 7875-2000
Jul 22, 2010 | NCR 7875
NCR scanner scale 7875 communicating with pc
You would need a PC to communicate it with. Either Via USB or the DataRX port.
Capital Computer Group, LLC
651-405-8293
www.capcom-ncr.com
We specialize in the NCR arena, also have many other point of sale needs.
Free bench testing equipment failure on any p.o.s hardware item.
Mar 18, 2010 | NCR 7875
Reading Small barcodes using NCR 7875 Scanner
we've had the same problem and usually it is a programing issue,Go to the MFG website and get the barcode program and that should help
Apr 08, 2009 | NCR 7875
7875 scanner/scale error code 4.
Problem is with the scale part of theunit, it needs calibrating, you can do this but you do need a set of weights, and it also depends on what country you are in reference the legality after you have done this. But chack fist the top plate is OK not damaged and sits OK, press scale zero. If that does not work there is a cover at the front of the unit sometimes with a seal over it or through the part that stops the cover being shown. Press the button under thisand follow the audio instructions, you will need 2.5kg, 5kg & 10kg or 5lb, 15lb & 30lb depending on ncountry you may need Weights & Measures in to verify afterwords depending on legalities
Mar 26, 2009 | NCR 7875
Enabling NCR 7875 flatbed scanner to read Code 128 barcodes
On a 7876, you need to scan the sequence “17130” is to add 128 tag readability. Not too sure if the 7875 is the same.
Feb 18, 2009 | NCR 7875
Setting Scanner and scale back to default settings
Print and scan the barcode below, this will set the NCR scanner/scales to defaults.
Dec 23, 2008 | NCR 7875
NCR 7875 Scanner/Scale Communication problem with PC
You need another cable (the metrologic cable doesnt work with the same configuration) and set the button in the interface card to rs-232 and program the scanner-scale with the programing tags.
Dec 04, 2008 | NCR 7875
Error 230 en Escaner NCR 7875
You need disable the scale scannig the bar codes for programing
Program mode
304
save and reset
301lbs to kg
302kg to lbs
303enable scale
304disable scale
305 Protocol comunication
306 Protocol comunication
307 Protocol comunication
Oct 08, 2008 | NCR 7875
7875 read two times one tag
Hello
This problem can be solved with some configuration that there are tags for 7875-2000 NCR scanner, what is here is the set of EEPROM targeta NCR scanner that brings you to continue to double reading of products
Jun 11, 2008 | NCR 7875
Computers & Internet Logo
1,575 people viewed this question
Top NCR Computers & Internet Experts
John Hong
John Hong
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
