Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Osd lockout i have a hp pavilion w2207 that display osd lockout
  • 8 more comments
  • hellofav8 Aug 05, 2008
    hi my name is steven
    I'm having trouble with my monoitor.
    ok where do i begin?well i tried to turn up the volume and adjust the contrast but i couldn't do any of them coz it said osd lockout and i was like saying wat the f#@k is osd lockout, and now its sayng osd lockout everytime i try to use my keyboard and its getting worse i dont wont to send it to a tech coz they charge to much $$$$$ out of ya and i dont have that kind of monies well anywayits an awful thing wat its doing to my computer its like its taking over everything its like a bug/virus sort of thing
    my computer is a HP Pavilion a6000 series vista Home Premium.
  • Anonymous Aug 15, 2008
    same as above
  • Anonymous Aug 18, 2008
    OSD lockout flashes in middle of screen ty...
  • Anonymous Sep 12, 2008
    I have somewhat the same prob., but when I push any of the 4 buttons on the lower right - hand corner of my monitor, (HP Pavilion w2007 - 20 " Flatscreen - monitor), the OSD Lockout appears & stays on for around 10 seconds.
    I've tried you're suggestions 1. holding down Menu - 10 sec. & so on, but nothing appears to work. ( the OSD lockout just stays on the duration of the 10 seconds then disappears )
    Does the computer need to go thru the re-starting process after the Menu - 10 sec. procedure ?
  • helmsharry Oct 04, 2008
    i dont know how to unlock it wont let me turn up the volume
  • Anonymous Jan 10, 2009
    osd locked on screen
  • Anonymous Jan 23, 2009
    OSD Lockout displays and wont go away.
  • Anonymous Apr 19, 2009
    I had the same problem and tried " holding down the menu button for 10 seconds" and it worked. Problem solve. Thanks
  • Anonymous Mar 13, 2014
    can not reset osd lockout
  • Anonymous Mar 16, 2014
    red and green screen krrp flashing no words
Hold the MENU button for ten seconds to unlock or lock the OSD
Posted on Aug 19, 2008
I JUST FIXED THE PROBLEM WITH THE MONITOR VOLUME POP-UP VIA OSD LOCKOUT! TURN THE MONITOR OFF, HOLD DOWN THE MENU BUTTON, WHILE HOLDING IT DOWN TURN ON THE MONITOR.....THIS WORKED FOR ME!
FRANCISCO J. PALACIOS
BOCA RATON, FL.
Posted on Mar 22, 2009
For HANNS G to fix the problem:
When the function key is locked (enabled) only the power button is active. Press the up and down Volume buttons and the Menu button simultaneously again to unlock the function keys.
Posted on Nov 13, 2008
All i had to do is place a screwdriver between the (black) screen and the (silver) plastic casing. I twisted the screwdriver so the two parts came a bit apart (so the silver casing bends a bit(it will bend right back when you take the screwdriver out)). Then i heard a click, that released the stuck Menu button. Now i have no problems anymore and the monitor is not scratched or anything. Dont know if this will work for other people, but for me the problem is now fixed.
Posted on Oct 17, 2008
  • 4 Answers
Hello everybody,
I know how to fix this, but it involves opening up the monitor....
First unplug the monitor and get all the cables out. Then get the monitor of its monitor stand, this is done by unscrewing the four screws at the back of the monitor stand.
Now you can pry open the case with a flat screwdriver. On the inside you see a small electronic board with the power switch and the other switches on it. These 'broken' or dirty switches are what causing the OSD lockout.
Get the small board out of it's bracket and use some ETHANOL or ALCOHOL (atleast 70% pure) to clean the switches, you just spray or drip the ethanol into/onto the switches. This will clean the switches of any grease residu. Then spray the switches with air out of an airspray can untill they are totally dry.
Now you can put everything together and voila! it is working again!! atleast it worked for me :):)
This fix will only work if the switches aren't broken but only dirty or a little bit stuck, if they are broken then you would have to solder new ones on the electronic switch board.
Good Luck!
Ralph S.
Posted on Dec 23, 2008
  • 8 Answers
Hold the menu/ok button for ten seconds, to unlock the OSD.
If this doesn't solve the problem, then it's probably the button that got stuck.
There are two things you can do to repair it, but both require that you dismantle the casing, which voids any warranty.. so, if the monitor's still covered by the warranty, or if money is not an issue, have it repaired by professionals on an accredited brand shop (check your warranty details for more information on this subject).
If not, remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.
If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers.
Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
This is a tried and working solution, since I had this problem myself (with a Philips 190B monitor), and solved it successfully, with this method.
Posted on Sep 25, 2008
  • 3 Answers
Osdlockout neovof417
Posted on Sep 07, 2011
The main menu keeps poping up in the middle of the screen and osd lock out. this is driving me
crazy. how do i fix this.
Posted on Feb 11, 2009
No, It makes the menu pop up and the menu wont go off !!
Posted on Aug 23, 2008
My monitor says OSD LOCKOUT how can i fix it?
Posted on Sep 17, 2008
I have a hpw2207h monitor that says osd lockout !!!!!! How can i fix it? Thanks
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds. If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
Jan 18, 2011 | HP w2207 Monitor
I have a hp 1530 flatscreen monitor when I push the menu button on the screen it blacks out...and says osd lockout...what does tht mean...I have to unplug it in order for it to come bck up
OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
If you still have problems, click on this link for further instructions :-
http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
Dec 29, 2010 | HP Televison & Video
This osd lockout pops up quiet often on my screen what can it mean?
Try this
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"....if the problem continues. Switch of the monitor and remove the power cable and connect it again.
Mar 25, 2010 | HP Pavilion dv6000z Notebook
How to stop osd lockout from coming on screen?
Press and hold the power button of the monitor until you get another message something similar to "OSD unlocked"....
If the problem continues. Switch of the monitor and remove the power cable and connect it again
Also u can try to do a factory reset of the monitor
Hope it helps u
All the Best !!!
Mar 25, 2010 | HP w2207 Monitor
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
HP w2207 LCD monitor, the volume control window stays on
The volume button is stuck or defective. You can try massaging it around or spraying some contact cleaner in there but it's probably not worth the trouble since it's still under warranty and HP will replace it for you. Call 1-800-HP-INVENT and let them know what is going on and they'll take care of it for you.
They'll ship a replacement to you along with a return label to send yours back to them prepaid. You'll probably have it by the end of the week.
The OSD lockout won't help you in the meantime, the volume display won't come up but you'll get an OSD lockout nag instead.
Good luck, if you have any trouble filing a claim, let me know. We're an HP warranty center and can handle it for you as long as you get permission from Fixya first.(assuming you're in the US)
btw, this unit has a 3 year warranty and has been out only about 2.5 years so it's 100% that's it is still covered. Shouldn't be any issues regarding proof of purchase, etc.
Jul 28, 2009 | HP f2105 21" LCD Monitor
Osd lockout
osd is ON SCREEN DISPLAY.
Jun 10, 2009 | HP w1907 LCD Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
2,949 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
