Question about Microsoft Xbox 360 Console
No video output
Got a pixelated image (watered loooking image), audio still ok.
Next, video output disappeared and the TV reports "no signal;" however, I still have the audio output.
Tried different set of A/V cables, no change. Any suggestions?
  • recspinr Aug 11, 2008
    I have the same works for a couple of days , then it's like a shower screen, no video but still have sound.
    Here's the best part of red ring of death.
    Please help
  • Anonymous Aug 31, 2008
    audio is working but no video.. The screen colors were running and then the video went out
Ben007 is wrong, it's the console. Try calling M$ Customer Service, and if they make you have to pay to fix it, cook it alive with a towel, making the Console get the Red Rings of Death
Posted on Aug 10, 2008
    Problem Solver:
  • 9 Answers
Your TV is either dysfunctional or broken, not your console.
Posted on Jul 29, 2008
Panasonic th 46pz80u
Yo don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV is a fixed pixel device. The panel has a resolution of 1920x1080 pixels. The incoming video signal is scaled to fit that display. If the signal is 480i then it is deinterlaced to make it 480p, and then scaled up to make it 1080p. The amount of detail in the picture doesn't change. It's still a 480i image. It's just blown up to fill a 1080 panel.
The TV reports the resolution of the incoming signal before it is scaled. If you have a BD player you can see the effect of changing the resolution setting from 480p, to 720p, to 1080i, to 1080p 60, to 1080p 24. The last three (the 1080 resolutions) shouldn't look too different with a Blu-ray apart from movement because the native picture is 1080p 24 and the TV is simply converting it back to 1080p 24 for display.
960i is a funny resolution. That would be achieved by line doubling a 480i signal. But it's not one of the VESA HDTV timings. TTBOMK there's no Blu-ray or HD source that generates a 960i image. So even if you could generate it then the TV wouldn't understand what to do with it.
Aug 25, 2014 | Televison & Video
Scan lines missing
wow..that's most definitely a video drive error. 1. Check to see your settings are good still. It's not out of the realm of possibility that something glitched in the settings. 2. Missing information is a video drive issue, period. I'd suggest that you have a video board that's truly unhappy. Is this still under warranty? Hope so, since these service calls can run some serious dough.
Feb 11, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
How do I hook up dvd to tv
If your TV has the standard analog audio and video inputs (yellow, red and white jacks) or for better image (S-Video rounded 4 pin jack or component video red, blue and green jacks), you'll only need the corresponding cables, and also your TV could have HDMI port (digital video and audio signals), you should use this connection, all depends of what type of outputs provide your DVD/VCR, in the case your TV set doesn't has any of mentioned inputs, you still could use the antenna input and connect its matching output from DVD/VCR , tuned at VHF channel 3 or 4.
Feb 12, 2011 | LG RC897T DVD Recorder/VCR Combo
Tv only accepts signal from the single black cable cannot get the tv to recognize the 2 audio cables and one video cable.. how do i fix this?
Your Emerson TVs audio format is not stereo; it is mono. Therefore only one audio input will be active. There is a Note give on your TVs manual. I copies it here for your information.
1. VIDEO (IN) jack- Connect to the video
output jack of a video camera or VCR.
2. AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
Dec 21, 2010 | Emerson EWF2004 20" TV
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
Picture/audio problems on my HDTV
This is a cable box problem. Could be a lack of signal stregnth or bad HDMI output.
The SA boxes have a very bad history of this, try using the component video output and see if the problem persists.
The HDMI is a real glass jaw of those boxes; but this problem could absolutly be your incoming signal...high def channels require more signal strength and that is what causes audio drops, pixilation and flicker.
If it was the HDMI in the receiver/tv you would get:
- Black screen, Pink fuzz or green streak dropouts.
- "Fireflies"
- Audio cutting in and out
- Not pixilation!
So what is my approach? If the box is rented or under warranty get it replaced. If the problem persists then call your cable company and arrange a service call at their expense.
If the box is not under warrenty go ahead and call the cable company and complain about a poor signal. If the signal is good, use the component video looks almost identical anyway.
Let me know if this helps,
Feb 03, 2010 | Sony STR-DG820 Receiver
Vga audio in
VGA does not provide sound, only video signal.
to get sound, you need to run a signal from the audio output of the computer (1/8" mini) to the audio in of the TV (RCA).
Sep 06, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
No video output
get a screw driver un do ur hard drive and slice the **** out of it
Sep 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
