Question about Panasonic PV-V4021 S-VHS VCR
Re: Model PV-4523S
This Panasonic vcr was bought a few years ago and was working
perfectly until just a few days ago. I set the timer to record and
when I came home I ejected the tape and some of the tape pulled
out. I was able to remove the tape. I unplugged the vcr for a while
and then tried to record again and everything was fine. A few days
later the vcr is "eating" tapes again and not even recording.
Please tell me how this problem can be resolved.
Thanks,
M.
  • mscandura200 Jul 29, 2008
    Thanks for your help. I did used a VCR tape cleaner just last
    week. I wouldn't want to do that now because the VRC would
    "eat" that tape too. I would not take the top cover off as I'd leave that to a pro. If it is a motor problem it may be more worthwhile
    to buy a new vcr as it could be expensive to fix. Do you happen to know if that particular model is still available? I really like
    this VCR...so easy to use and the performance was excellent
    Thanks,
    M
    I immediately checked Ebay saw similar models but I don't
    want a used VCR and that's all I saw. I'll check other sites
    and stores maybe the same or a similar one will turn up
    somewhere. In the meantime I'll have this one repaired
    and start using a high grade tape and have the VCR
    professionally cleaned. I was told that the store bought
    VCR cleaners can somehow damage the heads and
    pinch rollers so that's not good. What I don't understand
    is that how can it work fine one day and not the next??
    Thanks,
    M
    Problem Solver:
  • 11 Answers
You have a problem with your "idler" , your belts or your "pinch roller". All VCR's get hot. Heat dries out the components I mentioned. (They are all rubber). Your pinch roller pulls the tape through the machine as it plays, The belts wind the tape into the cassette. The Idler helps rewind and fast fwd the tape.
Jim
Posted on Sep 28, 2008
  • 4,234 Answers
The problem is that the "idler" assemby has gotten slippery. This is either a rubber tire or perhaps a gear that is driven by a belt inside the machine. In either case, this is a simple repair and is common as machines age. This should be a $75 repair including parts. The pinch roller (rubber cylinder) is what pulls the tape across the heads in a steady fashion and has no role in keeping the tape inside the cassette. This is handled by the idler assembly and works for FF/REW and PLAY. Also, a cleaning tape will clean the heads but not effect the pinch roller.
Dan
Posted on Jul 30, 2008
  • Panasonic Master
  • 2,794 Answers
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Posted on Jul 29, 2008
  • Tim Babcock
    Tim Babcock Jul 29, 2008
    I don't see too many S-vhs format ones out there. You might want to check on Ebay and see if that particular model is for sale on there.
VCR stops recording by itself after a couple seconds.
Some VCR's will stop if the signal is not there. Retune the set if it uses Freeview. The broadcasters and those who are in charge of Transmitters like to mess around with the stations from time to time. This will effect the recording if you are using a model with the Guide Plus system. If you are timer recording it make certain that the settings are good. If it is an older model, make certain a thing called PDC is not on.
Dec 16, 2015 | Panasonic PV-7450 VCR
Timer mode is locked on vcr
You must have set a timer record. Press the button that sets a timer recording and cancel them. If you have the manual check what it says if you don't have a manual Panasonic do have PDF of most videos free. IF you can't clear try the factory reset opition.
Jan 14, 2013 | Panasonic 4-Head VCR PV-V4525S
How to set up my old vcr to a panasonic tv and get it working.
The VCR should set itself up. But if it doesn't have a digital tuner then it will not find any stations. You will just have to cancel that bit and do the rest. You can connect a set top box to the scart socket 2. If you want to record you have to set the timer manually and set it to record scart 2 not a channel. If the VCR has PDC set it to off.
Dec 05, 2012 | Panasonic Pv-v4530s Vhs Vcr Omnivision
VCR Model Panasonic NV-J45:- Until just yesterday, it worked fine, only last night I tried to play a tape, the green auto-tracking light flashed a few times as usual, then the tape just kept stopping, no...
The problem is caused by the idler assembly which controls play, record, rewind, and fast forward. If the take up reel stops, the vcr senses a problem and will stop the tape. The only other thing it can be is the drive belt, sometimes it will stretch and fall off or break. I suggest a tv technician or somebody that knows their way around a machine.
Jan 14, 2011 | Panasonic PV-9451 VHS VCR
We just purchased a Panasonic VCR/TV Universal remote for our PV-V4021 VCR and find we no longer have a user guide. How can we set the VCR to record at a later time, such as later in the evening? Where...
The problem with universal remotes is that unless you enter the correct code for that model not all functions will operate. You need to try every Panasonic code in the code book, untill you find one that works the guide function. Otherwise the only real solution is to get the original remote.
Aug 21, 2010 | Panasonic PV-V4021 S-VHS VCR
I have a Panasonic VCR PV-V4202-A. I want to
You need to go into the menu and look for timer recording,then set in the channel,dateand time the program starts,then press the timer button.It will not start recording until it gets to the time the program starts.
Sep 11, 2009 | Panasonic PV-V4022 VHS VCR
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
Panasonic omnivision PV-V4021
Read the book. ........... Get one.
Apr 17, 2008 | Panasonic PV-V4021 S-VHS VCR
Picture is jittery and voice is garbled with noise in background
I had the same problem recently with a Panasonic PV - V4521 which has worked for years for me. I tried everything including cleaning the heads with Q-Tips and pure alcohol. Nothing improved. I tried tape head cleaners. Nothing. So finally one day, as I was unscrewing the cables, this VCR fell down onto the bottom of my foot and drew blood. Now remember, I had been trying to fix this thing for at least 10 days.
So, I dragged it up and pounded the top of the VCR until the top caved in. Then, I opened my front door and tossed it so hard against the floor of my patio that pieces went flying everywhere. I gathered up the pieces and the twisted VCR, put it in a box, and tosses it real hard into the dumpster. It's fixed. I have no more problem with it.
Jun 27, 2006 | Panasonic PV-V4021 S-VHS VCR
Panasonic PV-V4021 S-VHS VCR Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
