Question about HP PSC 1410 All-In-One InkJet Printer
How to Remove the Ink Cartridge on My HP PSC 1410
I have lost the paperwork explaining how to remove the cartridge so I can put in the new one. Im sure its easy but I dont want to break anything so I though Id ask. Thank you.
  • cherylsky Aug 01, 2008
    I also do not know how to put in a new cartridge :(
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Here is the link which helps you to install the new cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00316915&dlc=en&product=441115
Regards,
Sagarjd
Posted on Aug 01, 2008
How do i remove the ink cartridge from my hp psc 1410 printer
It is very simple to remove the cartridges out from the printer if the printer is not in a error state.
Printer should be Powered on.
Open the front access door ( not the scanner lid )
The carriage which holds the cartridges should automatically move to center.
To remove the cartridge, Press the cartridge down ( with thumb ) and pull it out.
Do the same for other cartridge too.
If for any reasons you are not able to see the carriage in center position, try to move it manually in center to remove the cartridges.
IF none of the above steps help you remove the cartridges or the carriage is stalled on right side or left side, there are likely chances the printer is Defective.
Thank you for contacting FixYa.
*Please rate this solution with thumbs up
Nov 20, 2010 | HP PSC 1410 All-In-One InkJet Printer
HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
This eror usually mean that the printer cartridge has not been installed correctly. Try re-installing the cartridge. This error can also be generated by a logic fault within the printer.. if this is the case, replace the printer.. trying another new cartridge can be expensive so try and get a second hand cartridge, maybe from a friend and try that one.. Otherwise, replace the printer..
Oct 27, 2009 | HP PSC 1410 All-In-One InkJet Printer
I have refilled my black ink catridge in HP PSC 1410 . now my printer does not print any pages . i have cleaned my printer catridges, still it's not printing any pages . plz tell me the detailed steps to...
Sounds like the printer thinks the cartridge is empty. Old PSC units had a 3 cartridge memory - you kept 3 cartridges and cycled them to trick the printer into thinking it had just received a brand new cartridge, rather than a refilled one.
Jun 16, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printerred ink problem
I know this might sound silly but there is pieces of plastic on the bottom of the cartridges that cover the holes to keep them from drying out, make sure they are removed and then reinstall the cartridges and see if that helps.
Feb 06, 2009 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 1410 all in one
If You have light or message about print cartridge or alignment problems
Cause: The incorrect type of paper is loaded in the paper tray.
  • Solution: The paper must be blank and white for the alignment to succeed.
    If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP
    Support by going to www.hp.com/support. Click Contact HP for information on calling for
    technical support.
Cause: Protective tape is covering the print cartridges.
  • Solution: Gently remove the plastic tape by using the pink pull tab. Do not touch the ink
    nozzles or the copper-colored contacts.
  • Reinsert the print cartridges and verify that they are fully inserted and locked in place.
Cause: The contacts on the print cartridge are not touching the contacts in the print carriage.
  • Solution: Remove and then reinsert the print cartridges. Verify that they are fully inserted and locked in place.
Cause: The print cartridge or sensor is defective.
  • Solution: Contact HP Support. Go to www.hp.com/support. Click Contact HP for information on calling for technical support.
(These help is from HP manual you can refer for details.)
Thanks
Iqbal
Apr 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
Can't figure out how to change ink in HP PSC 1410
heres the link for the manual for this printer , it will inform you
how to change the ink cartridges , hope it helps, just click here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=441115&lc=en&cc=us&dlc=en&lang=en&cc=us
Mar 30, 2008 | HP PSC 1410 All-In-One InkJet Printer
HI,got this new hp psc 1410 i have connected with my computer ,got photos ready but when i presse print it doesnt work,pls can you help.thanks
did you install the cd driver of your Hp psc 1410?
if not insert the cd driver of your HP printer, after auto play goes click install driver, just follow the instruction on screen, then finish,
remove the ink cartridge, check if ther a cover in the contact point of your cartridge, remove the seal,
Mar 12, 2008 | Computers & Internet
Hp 1410 all in one
Have you removed any tape that covers the vent holes on the cartridge. If the ink is a compatible one they often have a tape of bung that needs to be removed before you insert them.
Sep 15, 2007 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 1410 all-in-one printer not printing
What is not working? The printer or the cartridge? If it's the cartridge, try this. fold a paper towel in 4ths, dampen it and place on a flat surface. Blot the cartridge several times on the towel. You should get blots of black with the black cart. and three colors with the color or photo cart. If not... replace. If the printer carriage just won't move and you're shure you have power.. time for a new printer.
Aug 27, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
468 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
