Question about Canon P200-DHIII Calculator
Putting new paper roll in
I do not know how to put the paper into the canon p20-dx calculator. I have never used one of these before, so I am completely clueless.
  • hsmac Sep 08, 2008
    P200-DH III
  • Anonymous Oct 21, 2008
    I need to replace the paper roll and the machine won't grab the paper when I slide the paper into the slot.
It's difficult to see, but the feeder for the paper is on the back of the machine, just below where the roll of paper goes. You'll see a little slot above the opening for the batteries. Feed the paper in here and push the arrow up button above the ON/C button to get the paper feeding through the mechanism. It should pop out at the top!
Posted on Jun 30, 2009
If the paper won't feed, try:
1. cut the end of the paper roll with scissors so that is it a clean edge the mechanism can grab.
2. turn the power off for 10 seconds, then power back on and try feeding through again.
I was having the same problem and these steps worked for me.
Posted on May 20, 2010
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
How to remove E error on Canon P20-DX adding machine?
Check your owner's manual. Ok, ok I know you lost it, but you can download one from Canon. Is it possible you are exceeding the capacity of the machine? Is it possible you are low on ink?
Jul 15, 2014 | Canon P20-DX P20-DX Electric Type...
How do I add ink to the Canon P20-DH
It takes paper that does not need ink.
Sep 08, 2011 | Canon BP120 DH Calculator
How do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
Nov 06, 2009 | Canon P23-DHV Calculator
Cannot load paper into feed into machine
Put new roll of paper on paper arm with the end of the paper hanging down from the back. Insert the paper into the **** at the back of the calculator - you need to look carefully as it is not very wide. Use the feed key to feed the paper through. Hope this helps.
Oct 25, 2009 | Canon P23-DHV Calculator
Cannot load new roll of paper
It is actually quite easy.
1. The calculator should be powered and be "on" and the removable plastic should be affixed in its normal position (from this the paper emerges and the plastic is serrated to tear the paper when it comes out).
2. Take the roll of paper and put it on the spindle with the paper rolling toward you from under. Take the leading edge of the paper and physically lead it into the horizontal slot in the back of the calculator, and press the "arrow-up" button (on the upper left of the board) repeatedly until it catches.
For some reason, Canon does not make the manual available on line.
Jul 06, 2009 | Canon P23-DHIII Calculator
Paper Loading
Cut a diagonal to make a sharp corner on the end of the roll, then stick the corner into the paper slot, and then press the feed button.(arrow on top left)
Oct 18, 2007 | Canon P23-DHIII Calculator
Canon P200-DHIII Calculator Logo
575 people viewed this question
old marine
old marine
