Question about Xerox 5305 Copier
I found it in basement
Hello!
I recently purchased a new flat, and in the basement I found a Xerox 5305 Copier. I have no instructions, no guide, no nothing. I just want to know if thing works. But I don't know where to insert blank papers! Where is the paper tray? Is it beneath the carrying handle, or on the other side?
  • Anonymous Apr 19, 2009
    I was given the Xerox 5305 copier and I don't know anything about it. I have no book to look at the learn how to use it. Can I get a Book somewhere?
    Problem Solver:
  • 8 Answers
The 5305 was a portable copier and the paper tray attached to the platen cover (glass cover). It may be there. The device will not work without a paper tray. If it's been in the basement, you may need to make sure there are cartridges in it too before attempting to power it on. If there is not a toner cartridge, the device will not power on.
Posted on Aug 26, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Xerox Master
  • 1,362 Answers
Check this site for manual
http://www.nodevice.com/manual/Xerox.html
Posted on Jul 31, 2008
The 3 page ligths are blinking on my xerox 5305. what can i do?
u can clean ur fixing unit and hole photocopyar
and FDF unir
another
u can clean ur finger and
peniam
+8801723019697
Aug 06, 2011 | Xerox 5305 Copier
Xerox 5305 does not feed paper
Those old babies just keep going! You need some serious TLC. And, a feed tire no doubt.
Jan 29, 2011 | Xerox 5305 Copier
I want to repair J7 in Xerox 5317
If your ERU (drum unit) has made 40.000 copies you can repair it using the repair kit that includes the fuses.If it has reached 80.000 copies then you need to replace the drum.If you can't find either then take out the drum,locate the small pcb at the rear end (next to the gears) and replace the 2 small fuses.This requires a soldering iron and knowhow
Apr 06, 2010 | Xerox 5305 Copier
Error code L8 on XEROX model 5305
That indicates the main board has not sensed the exposure lamps coming on. Those are solder in lamps, I believe there are 6 or 7 on the array.
Mar 01, 2010 | Xerox Office Equipment & Supplies
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
Xerox c20 doesn't print. the paper runs through & comes out blan
hello sir; you said this one is brand new, did you follow the installation instruction, no matter what, just di it again,
1, press "menu" ,
2, press up/down arrow keys until"new drum" display
3, press "mode/enter"
4, when you see"new drum unit?" press "1" to select "yes"
5, turn power off and on .
Dec 28, 2008 | Xerox CopyCentre C20 Black and White...
Xerox 5305
sounds like the drum leaking, replace drum or other possibility Fuser.
Jul 31, 2008 | Xerox 5305 Copier
Xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Feb 27, 2008 | Xerox 5305 Copier
Streaks on copied paper
You have a failed drum cleaning blade that lives in the drum cartridge. The blade is replaceable as a seperate item.
Jan 31, 2008 | Xerox 5305 Copier
Xerox 5305 Copier Logo
219 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
