Question about Sony Ericsson K300i Cellular Phone
Please insert SIM
My cellphone hangs times to times, and states "Insert SIM" message. Then y remove the battery, remove the sim card, place it again and starts working. Any tip for solving it?
    Genius:
  • 1,011 Answers
Dear,
If the phone freezes
  1. Press and hold the on/off key.
  2. If your phone does not power down, remove the battery for 10 seconds, insert it again, and restart the phone.
Note: Use The Sony Ericsson Update Service regularly to reduce the risk of software problems. Make regular backups using Sony Ericsson PC Suite to reduce the risk of lost or corrupted information.
dont forget to rate me.
regards,
Posted on Jul 29, 2008
Phone ask me to insert simcard and hanging
It can't read your Sim Card. either your sim card or your cellphone
Jan 08, 2014 | Nokia E72 Smartphone
Toshiba sim card slot
SIM Cards are from cellphones. SD Cards are from cameras. Some laptops have the ability to accept SD Cards from cameras to download pictures. Normally you just push it in until it stops, and the computer recognizes it. When you want to take it out you just push it again and it pops out. I don't think you want to push a Sim Card from a cell phone in it.
Apr 21, 2012 | Computers & Internet
Every time i insert my sim card into my phone and switch it on it tells me to insert a sim card and the phone stays in offline mode and cannot be put back into general or silent(n70)
remove the sim, battery, and memory card then clean your sim with eraser then try it on. if problem continues try a new sim and if not work again no other solution but to consult a technician.
Mar 28, 2011 | Nokia N70 Cellular Phone
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Always show the message 'insert sim card', When I refitted the SIM and turned back on, I had no network coverage. it always again n again n again..
Hi,when a phone does that, it means that the memmory of the phone is malfunction and it needs to be restored..
To be able to restore back the phone memory, you will need to flash the phone memory.
The links below will give you a guide line on how to flash the phone memory .
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
May 25, 2010 | Sony Ericsson K530i Cellular Phone
Reset my cellphone
If the display says "Insert SIM," it means that the phone has no contact with your subscription card (SIM card) that is inserted in the phone. We recommend that you remove the battery and the SIM card, and clean the connectors on the SIM card and the phone with a soft brush, cloth or Q-tip moistened with any type of unflavored colorless alcohol.
At the same time, check that the card is not damaged or worn in any way, in that case, the connector may not align with the connector in the phone. Please contact your operator / carrier for a new SIM card.
Sep 21, 2009 | NEC L1 Cellular Phone
Nokia 6300 doesn;t work with sim card
Hi there, you may try to reset the whole software on your cellphone. Provided to back up all the necessary contacts, messages on your Cellphone. There is a need to update the software version of your cellphone to make it working again.
You
Jul 07, 2009 | Nokia 6300 Cellular Phone
Insert sim problem 1100,1600
sometimes it is as simple as cleaning the sim card and sim points on the phone with a pencil eraser. sometimes it is related to a simcard IC (usually placed close to the sim tray in the phone) so if u do not succeed cleaning the sim and sim points of the phone u need to change the simcard IC
Jul 02, 2009 | Nokia 1600 Cellular Phone
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Sony Ericsson K300i Cellular Phone Logo
95 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
