I need instructions for reinstalling the straps into my 3 in 1 Eddie Bauer convertible car seat. Thanks!I need instructions for reinstalling the straps into my 3 in 1 Eddie Bauer convertible car seat. Thanks!
I have lost my manual and need to know how to take off the extra padding and then how to put it back together?I have lost my manual and need to know how to take off the extra padding and then how to put it back together?
i cant figure out how to put the car seat strap back in the car seat after washing the cover for iti cant figure out how to put the car seat strap back in the car seat after washing the cover for it
You can't post conmments that contain an email address.
Contact a local certified Child Passenger Safety Technician (or equivalent if you are not in the USA) for help.qaa The reassembly MUST be done correctly (do not guess)!
Contact a certified Child Passenger Safety Technician (or equivalent if you are not in the USA). www.nhtsa.gov It MUST be reassembled correctly. Do not guess!
I have the same seats. All you have to do is pull the small teather
stap at the top of the child booster seat. You pull it to make it
tighter around the child or you pull it and then pull the child saftey
straps at the same time. You also do not have to purchase the manual if
you call chrysler they will send you one for free. That is how I got
mine.
ON THE BACK OF YOUR CARSEAT ARE 2 METAL LATCHES ON EACH SIDE. REMOVE ONE BE PUTING THE STRAP THROUGH AND ADJUSTING IT TO YOUR CHILDS FIT.YOU COULD ALSO PUT IT THROUGH A SECONDARY HOLE IF YOUR CARSEAT HAS ONE TO PROPERLY HOLD YOUR CHILD SAFELY.LET ME KNOW IF I WAS ANY HELP...
ON THE BACK OF THE CAR SEAT ARE TWO LATCHES SIMPLY REMOVE ONE BY PUTING THE STRAP THROUGH THE LATCH AND ADJUSTING IT TO YOUR CHILD FIT DO THE SAME TO THE OTHER. LET ME KNOW IF I WAS ANY HELP...
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal.
However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
