Question about Samsung DVD-HR720 DVD Recorder
Power supply down
Dear,
Who has experience with a power supply down failure of the DVD-HR720
No clock or lights visible anymore, no internal power supply available.
Who can help?
Thanks a lot
Jan
  • Anonymous May 12, 2009
    Yes I have the same problem
    Pat
My samsung dvd-v1000-vcr do not turn on
Posted on Aug 27, 2008
Vizio E550i-b2 has no picture
Could be an open internal fuse or power supply failure
Aug 16, 2016 | Vizio Televison & Video
OSD IS BLINKING
bad micro probably. could be power supply,might be better to replace
http://www.shopjimmy.com/
Sep 06, 2012 | Samsung DVD-HR720 DVD Recorder
Hi, I have few quick questions regarding the Intermatic HB114C 240 Volt, I would appreciate if you can answer my questions 1. Does this unit have Internal Built in Clock to set up the Clock or does...
HB114C timer likely will not work in India.
Contact Intermatic: http://www.intermatic.com/customer%20service.aspx
Plug type is different than found in India.
India power generation is 50 Hz, so timer might not keep time even with plug adapter.
US power grid is 60Hz, so US-sold products are 60Hz.
Some timers are both 50Hz and 60Hz, but spec sheet usually shows that information.
HB114C spec sheet does not show Hz.
http://www.intermatic.com/~/media/files/intermatic/products/fact%20sheets/timers/hb114c.ashx
http://users.telenet.be/worldstandards/electricity.htm
HB114C is analog appliance timer with clock motor that rotates dial once every 24 hours.
The timer does not have a countdown feature.
Trippers are placed on dial.
As dial rotates, trippers move small switch that opens and closes circuit to load.
Current time is set by manually rotating clock dial until current time lines up with arrow located on inner dial.
After power failure, current time must be reset.
There is no way to install a battery back-up inside the timer.
To see images
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Aug 15, 2011 | Intermatic HB114C Heavy-Duty Timer
LCD TV Akai 27" NO PICTURE, NO SOUND, JUST A POWER LIGHT
Mar 26, 2017 | Akai LCT2721AD 27 in. LCD Television
Panasonic dmres30v dvd/vcr combo total dead no clock desplay ,power ,could it be a fault in power supply sections ?
This could be down to one single component, a swollen looking capacitor. Normally 630uF capacitor on the power/digital board, located under the rear of the Ram drive. Tell me, did this failure happen afer you unplugged the unit?
Kind regards,
G
Jan 12, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
Faulty power supply board
I have exactly the same problem. Indeed the power supply was defect. I have repaired it. Now the display is working but it is still not working : It displays LOADING... and that's all. Probably the controller card (the one with the LSI LOGIC chip) is also defect. It is impossible to repair, it has to be replaced.
I think this recorder is not 'CE'.
Sep 25, 2008 | Samsung DVD-HR720 DVD Recorder
Dvd file system
The first is rather easy. You will have to finish the DVD to get it working. After copying a title, finish the DVD and put in you computer's DVD player. Either the film should start to play or you will be prompted whether you want to show the contents or other options. If either of this happens, you are good to go and you can copy the Video_TS folder which should be visible to your hard drive. Done it several times.
The second solution is something I try to figure out myself but it seems DV in is really IN and not OUT....
Best,
Marty
Oct 16, 2006 | Samsung DVD-HR720 DVD Recorder
Samsung DVD-HR720 DVD Recorder Logo
337 people viewed this question
Jerry Greenberg
Jerry Greenberg
