Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven will not stay on
I have a Kenmore oven #911.4012190. I can turn the oven on and set the temp to 350 and the temp will get to about 170 degrees and then turn off. I can then turn it on again and it will stay on about 1 minute then turns off.
  • Anonymous Aug 15, 2008
    My Kenmore Elite Range shows F1 all the time. I can turn it off and the time will appear and a minute later F1 appears. The oven can be turned on. It will start heatine. After a minute or two it will cut off and F1 appears. If I continually reset the oven and turn it on each time it cuts off I can eventually get the oven to heat all the way up to 350 degrees or better but to keep it hot I have to continually reset the oven every time it cuts off. The stove was given to me and I do not have an owners manual. Should I junk the stove or is there a fix for this problem?
  • creeves Nov 11, 2011
    Who is Charlie and what is the answer? I have the same problem but I don't understand the solution. THX
  • 4 Answers
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Posted on Aug 02, 2008
Oven is not staying at the set temperature. It will go as much as 200 degrees higher than set temp
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 04, 2010 | Kenmore 30169 Electric Single Oven
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oven temp stays 100 degrees above set temperature. Have adjusted digital controls but cannot bring it into range.
You obviously have a faulty thermostat,only solution would be to replace thermostat.
Jan 02, 2010 | Kenmore Ovens
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Oven temp. is off at times, varies how many degrees
Replace the thermostat, and it should solve your problem.
Please rate my solution.
Nov 09, 2009 | Kenmore Ovens
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
My oven won't heat to the right temp.
Check the temp censer in the oven It went bad.
Feb 26, 2009 | Frigidaire FEB27S5A Electric Single Oven
How can i quit cleaning oven?
During the self clean cycle, oven temp will exceed 900 degrees F. At these temps, if you opened the door, the food inside would immediately catch on fire when the supply of oxygen hit it. When you turn your self clean cycle off, the oven door will remain locked until the internal temp drop below aprox. 550 degrees F for your safety. Once the oven cool below this temp, you will be able to start using the bake or broil again. This should be a Fix-Ya for your oven.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
699 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
