Question about Cameras
RUN DLL ERROR LOADING C:/windows/system32/OVTFboot.dll The specified module could not be found Having same problem during installation of 35mm slide scanner. Managed to download a copy of OVTFBoot.dll from "Driver Agent" but install failed again with message: "Missing entry: OV550Start" I suspect that the correct driver is not included on the installation diskette provided by the manufacturer.
  • 2 more comments
  • quack5555 Aug 23, 2008
    Same problem here, I have uninstalled and reinstalled as many different ways as I can think of. We'll see what happens when I call the manufacturer (VuPoint Solutions Inc) Monday...
  • ningaloo Sep 05, 2008
    I have the same problem when attempting to install the hardware drivers of the VuPoint Scanner onto my XP machine. My system does not have the OVTFBoot.dll. Where can I find a copy?
    Al
  • networks Nov 21, 2008
    was running an install for a slide to digital image converter and this error came up....I uninstalled and reinstalled from the disc and from the web but that approach was useless....still faced with a nice new and inoperable slide scanner........help
    Dan
  • crackerjack6 Mar 01, 2009
    Installation of the Hercules web cam offers the same error OVTFBoot.dll not found. Im using HP home
Deluxe webcam version 1.4
Posted on Nov 16, 2008
Http://www.dll-download-system.com/home/o-dlls-not-system-/ovtfboot.dll/details.html
Download file and add it to system32, run driver installation again. Works on my Summit negative scanner. Good luck!
Posted on Jan 04, 2011
Icuin36.dll wont load of can not be found
Download the file from this site http://www.dll-files.com/dllindex/dll-files.shtml?icuin36, unzip it and paste in into the system32 root folder. You'll have to do this using another pc. Mount your hard drive on another pc, locate the C:\windows\system32 folder and paste the unzipped file (icuin36.dll), turn off the Pc and remove your hard drive and again remount on your Pc, now Power on your system, it'll be ok. You can also do this without using another Pc, but you have to know how to use command prompt. Good luck.
May 22, 2010 | Computers & Internet
Run DLL, VTURQjKC.dll problem
smash with hammer and try again
Apr 21, 2010 | Computers & Internet
I get pop up blockers on my computer every time i turn it on.
you have virus (melware) on your machine. do you have any type of anti-virus program on the machine/ if so, please run it. if not, go to vga.com and download the antivirus software, and run it.
Apr 08, 2009 | HP DeskJet 3000 Printer
RUN DLL ERROR
IF YOU HAVE ANOTHER COMPUTER IT WOULD BE EASIER, IF NOT YOU WILL HAVE TO PRINT OUT THE INSTALLMENT DIRECTIONS FOR ELIMINATION OF THE ERROR PROMPT. IT'S TIME CONSUMING SO IF YOU ARE IN A RUSH, FORGET IT.(UNLESS YOU ARE A COMPUTER GEEK) :) YOU WON'T BE ABLE TO ACCESS WINDOWS FROM THE COMPUTER WITH THE ERROR, GO TO ANOTHER COMPUTER, PULL UP WINDOWS SUPPORT, THERE'S A SECTION THERE FOR ERRORS, IF YOU DON'T SEE IT RIGHT OFF, JUST DO SEARCH ON THE LEFT HAND SIDE BAR, "DLL" OR "ERRORS" ANY OF THESE WILL PULL UP YOUR FIX. PRINT 'EM, APPLY, AND YOU'RE UP N RUNNING!!!
Oct 24, 2008 | Microsoft Windows XP Professional
M3plugin.dll
please tell us how to resore requird dll for error
C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
Sep 10, 2008 | Computers & Internet
While trying to install my printer I ran into some problems with the print spooler, while trying to fix this problem I get this message displayed RUNDLL Erro loading C:\Windows\System32\xmqlllnu.dll ...
I had a look at dllfiles.com and it doesnt list ur missing dll.
I would suggest getting the latest drivers for your printer, uninstalling the old ones and install the printer again.
If your print spooler is disabled then you might have issues as well. Just make sure the spooler is enabled. Click run then type msconfig and hit enter, under the serices tab make sure that print spooler is checked, spoolsv.exe is the command.
But firstly fix the drivers for the printer cause that looks like a service specific dll thats missing for the printer
Hope that helps
Let me know
Aug 22, 2008 | Computers & Internet
OVTFBoot.dll
OK ya must be trying to install into Vista? anyway whats happening is ya NOT using Admin mode... and that DLL isn't being allowed to be put in the system32 dir... so disable UAC open admin prompt and find it, & copy .. so after ya install find the DLL on the install media .. then copy and paste it to ya windows\system32\ dir.. register it if reqiured should be all good.
Better still install properly with admin rights and such. GL
Jul 29, 2008 | Office Equipment & Supplies
M3plugin.dll
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
pentium iii windows XP
the specified module could not be found m3plugin.dll it appears on startup on windows xp and i want to fix it
Jul 28, 2008 | Intel Motherboard
Most times DLL errors arise from a file being corrupted on your hard drive and there's a relatively easy fix for it.
the best solution is to re-install the drivers for your specific printer either from the disc provided by the manufacturer or from a downloaded file from the manufacturer's website.
Jul 01, 2008 | Office Equipment & Supplies
Cameras Logo
2,147 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
