FALCON 320 SHUTS DOWN
Hi, I have a Falcon-320 from PSC. When I hit the laser trigger the Falcon shuts down, Battery level full, tried with new battery, if data is input manually it works. Did a Factory default and re programed it. Still does this. What can I do?
Thnks, I did read the manual I must have missed something?. I will apreciate if you can really help posting a solution not a possibility.
Posted on Aug 15, 2008
    Problem Solver:
  • 5 Answers
Try to read your manual.. it might help you..
Why does a ba falcon shut off when hot left for half an hour it will start again
very annoying and could be dangerous
after what has been fitted
leaves the coil packs/ spark issue
idle control sensor
02 sensor
the maf
other unknowns
a shut down like that ..could be a module of a sensor
the engine light should be on
saying the engine computer has fault codes to read
down load the free repair manual of you dont have one
only one download not for resale etc etc
Ford Falcon BA 2002 2005 Workshop Manuals Factory Service Manuals
good you replaced the CAS
first thought was the crank angle sensor
you toss water on it and if the car starts up its faulty
Oct 14, 2016 | Cars & Trucks
Brake lights still not working just replaced brake swich,help
Have you checked for 12V at the bulb holders themselves? If 12V present, bulbs are bad or open ground at the light socket.
Aug 07, 2014 | Empire Comfort Systems E.F. Johnson BP196,...
06 ford falcon wont do nothing wont start or turn over new bat
Bad or loose battery cable(s). Tighten the connectors on all ends, and go hand-over-hand to inspect them for fault or damage.
Just enough juice to make the radio work but not enough to turn it over, right?
Try this test: Turn the headlights on, then try to start it. If the headlights (or interior lights) dim down or go out, then if it ain't the battery, it surely is one of the vables or connectors.
Jul 20, 2014 | First Years The Red Stripe Ingnite...
Engine fuse burn when i start car.
Not much help here and I apologize but something is not grounded properly and causing this to short out. This is going to have to be a one by one elimination and I would start with the engine grounding strap first then to starter, alternator and work your way along the electric until you find something ungrounded or disconnected.
May 20, 2014 | Empire Comfort Systems E.F. Johnson BP196,...
Honda falcon nx4 gas leak from carburator when I turn the valve on, only when it is parked
While it COULD be the float level is set too high, if you haven't had the float bowl off, more likely it's some crud in the fuel got stuck between the float shut off needle and it's valve seat.
This doesn't allow the float needle to shut off completely, and fuel will keep coming into the float bowl, even though it's already full.
This is more pronounced with the engine shut off, and sometimes at idle, and less so as the engine revs increase.
This is because the faster the engine is running, it's burning more fuel, and better able to keep up with the overflow.
Apr 16, 2014 | 2005 Honda NX4 Falcon
Wiring diagram for ford ef falcon
Hi Kelly,
You've posted on the wrong forum, you need to post your query in the Cars & Trucks forum.
Cheers,
Peter
Dec 31, 2012 | Empire Comfort Systems E.F. Johnson BP196,...
My 1998 falcon has a noise coming from left front wheel area when it hits rough patch can find what it is any ideas thank you John
could be shock absorber on the way out, check shock absorber for any oil leak down the side, also when parked press down on front left wing and see if car comes back up and stops or comes up and down a few times until is stops, if the latter this means you need a new shock absorber fitting.
I hope this was useful
Jan 24, 2011 | Falcon 4420
Twin Client Software manual or installation guide for the PSC Falcon 345. Where can I find it.
researched the internet for the manual.
and I found it.
Thank you for your no-help!. unless I dish out $$$.
Oct 06, 2009 | PSC Falcon 345
High beam shuts off when on for a long time ford ed falcon
try changing your high and low beam relays, and maybe install a relay for each light, all fords have the same problem
Dec 18, 2008 | 2002 Honda NX4 Falcon
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
