Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon PIXMA 160
There must be a way to reset E4 error and empty cartridge errors after using refill kits in printer. can anyone help?
  • dsdcolo Aug 09, 2008
    I can not use the printer without the colour cartridge.(The colour one is empty)
    It is another way to fix it that i have to buy one and replace it ?
  • sharcos Aug 09, 2008
    I have the same problem. How do you reset the ink level details after refilling the cartridges? The ink level in both cartridges are ok and the printer will print, but the ink detail window still says ink level is low. Please help
In cannon mp 160 I can not use the printer without the colour cartridge.(The colour one is empty)
Posted on Apr 18, 2011
Any coloured scan is blue
Posted on Aug 07, 2008
  • 27 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
601
Posted on Feb 27, 2009
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
My canon PIXMA MP450 all-in-on-printer is showing U059 the following ink cartridge cannot be recognized i tryed to put the old ink tank in but it said the same thing
Basically, there is no solution for your case. This happens especially for Canon product.(called e5 error) Once a cartridge is not recognizable, there is no way, you can use it.
The only way you can do is, replace with brand new one. This is typical Canon problem especially when you refill or re-use your cartridges.
You may see some solution from web such as reset the printer, do somthing to printer software... But non of these methods are working.. Even if there is one, it must be very difficult to do it for individual users.
However, as for a prevention, make sure unplug the power cords before insert or eject the cartridge from printer. In that way, you can at least reuse your cartridges for refill. Hope it helps.
Dec 13, 2011 | Canon PIXMA MX310 All-In-One Printer
Have loaded refill cartridge into my Canon 210, does it need to be recalibrated as it is not printing evenly there are strip sections missing, also cartridge empty is showing up when it's not empty?? Is...
Canon recommend only original cartridge,if you refill the cartridge quality is poor and the printer to give you error.If a have been useful please give me a vote :).Thanks
Apr 14, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA mp240 All-in-one InkJet Printer. Error code: 2,140,2
If you get a warning regarding Ink is Empty and even you cannot Scan your documents then you might require a small R&D, Just hold Stop/Reset button for about 5 seconds, then open cartridge access door, Remove both the Cartridge's and wipe it with the wet tissue or cloth... spray water or deodorant on the exposed golden surface of the cartridge and do not let it dry, install as soon as possible... Then close the cartridge access door and switch off your printer, then Re-start it and connect to your computer, Hold Stop/Reset button for 5 seconds and then enjoy scanning...
Dec 09, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon pixma mp 145 E4 problem
Dear Sir,
Error Code E4 = No ink.
Generally printer doesnt recognise refilled ink.
Try the to reset the ink catridges
by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
if you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Code E4
A Canon MP145 E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you're using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, the first Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY.
Below are the manual way to correct this problem :
  1. Turn On Your Printer.
  2. Wait Till The Printer Led Screen Show The Error Code ( E4).
  3. Then Press and Hold Black & Color Button for about 5 - 10 seconds.
Hope that your problem is solved.
Aug 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a problem on my canon mp145 with an error code E4. But I already change it to a new cartridge but still the error code still appears. I also reinstall the drivers but still the same.
Hi, I found this answer on the net. Let me know if this helps
A Canon MP145 E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you're using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, the first Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY. Below are the manual way to correct this problem : Turn On Your Printer. Wait Till The Printer Led Screen Show The Error Code ( E4). Then Press and Hold Black & Color Button for about 5 - 10 seconds.
Thanks
Ranjit
Aug 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Refilled cartridge, mx310 does not recognise they are refilled and I get 1686 error can you help please
You need to buy the little circuit board that is on the cartridge. The chip tells the machine that the ink is empty. If you're going to refill, you need the chips as well or a chip resetter.
Jul 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Mp 145
How to reset the e27 for canon mp145 printer?
May 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
251 people viewed this question
old marine
old marine
