Question about Kirby Vacuums
I can't get the vaccum cleaner to convert to a carpet cleaner
    Problem Solver:
  • 7 Answers
What do you mean, are you refering to carpet shampooer attachment
Posted on Jul 29, 2008
Why is my carpeting getting fuzzy tips?
You might be vacuuming too much or you may have the wrong brush strips for your style of carpeting. I recommend you take a sample of your carpet to your Riccar dealer and ask them if you have the correct vacuum and brush strips for your type of carpet.
Aug 02, 2014 | Riccar 12 8000 Simplicity 7000 Type B...
Tip
How To Attach The Carpet Shampooer To A Kirby Generation 5 (G5) Vacuum Cleaner
The Kirby carpet shampooer is an attachment that is used with the Kirby upright vacuum cleaners. It converts the Kirby from being used as a dry pickup vacuum, into a carpet shampooer and extractor. Unlike other carpet shampooers and carpet extractors, the Kirby shampoo system does not saturate the carpet with a lot of water when cleaning. Kirby shampoo systems use a special dry foam formula that gently cleans the carpet without saturation.
Installation
The link below is to an excellent, easy to follow and understand video that will explain step by step how to convert the Kirby Generation 5 (G5) from a vacuum cleaner into a carpet shampooer. Please note that the vacuum in the video is actually a newer Sentria model, however the repair procedure is identical on the G5 as it is on the Sentria.
Video Demonstration of Converting Kirby Generation 5 From Vacuum Into Carpet Shampooer:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If you have any questions about the procedure of converting the Kirby G5 into a carpet cleaner, please feel free to request clarfication on this video right here on the Tip page. I hope that this video was helpful. If you did find the video helpful, please kindly rate this Tip as helpful by clicking on the Thumbs Up Icon in the lower right hand corner of the page.
Thank you very much for watching,
Chris J.
on Mar 21, 2010 | Kirby G5 Bagged Upright Vacuum
Electrolux VACUMM CLEANER LITE II
get new bag filter , empty dirt out to garbage bag , clean hose .
Dec 26, 2013 | Vacuums
It won't vacuum up the solution from the carpet
Check the filter located on the top of the water holding tank. It's red and if it's clogged it wont allow the vaccum to **** water. Good luck
May 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
Jul 23, 2009 | Kirby G6 Bagged Upright Vacuum
About kirby carpet extracters
The heritage 2 pulls 5.5 amps or 660 watts in hose mode and 4.5 amps or 540 watts in carpet mode.
Volts to Watts
The conversion of Volts to Watts is governed by the equation Watts = Amps x Volts
Mar 24, 2009 | Kirby Heritage II Vacuum
Plugged hose on Hoover Windtunnel
you will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
Dec 31, 2008 | Hoover Windtunnel Supreme U5280-900...
Vacuums Logo
59 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
